Emulsion tubes (again)
Posted: Wed Jan 30, 2013 12:29 am
by jjmoto
My TRX is displaying the usual running rough at around 3500 RPM symptoms, my question is what are the options when replacing them, (£28 each from my local Yamaha dealer), i don't know whether to go for the complete carb refurb kit, or a Dynojet or whatever other jet kits are available. Its running a K&N filter in the stock airbox & Simmi race cans, i've not re-jetted since fitting them a couple of years ago & its always run well till recently. Any advice greatfully accepted cheers.
Re: Emulsion tubes (again)
Posted: Wed Jan 30, 2013 2:24 am
by Con Rod
Kedo
http://www.kedo.com/
do entire carb kits for 50Euro
or you can buy just the needles and tubes, (12.50each needle and 12.50each tube)
Kits can be got in the UK, as discussed here:
viewtopic.php?f=36&t=7983&p=84385&hilit ... +uk#p84385
these guys in Australia do kits for AU$45
http://www.motorcyclespareswarehouse.co ... -parts-kit
loads of info in this thread
viewtopic.php?f=26&t=7265&hilit=emulsion+tubes
for non standard parts you can go Dynojet or Factory Pro. These options are more expensive
If you just want to fix the fuelling problem then go with a replacement kit. If you want to rejet your carbs go with Factory Pro or Dynojet
As detailed in the thread above I am using a standard carb kit with a K&N Filter and race cans and have a set up I am very happy with. I have no experience with the Dynojet set up or Factory pro.
Posted: Wed Jan 30, 2013 11:45 am
by Silver
You can get individual parts in the uk from ;-
http://www.allensperformance.co.uk/
I've bought just the etubes from them, but they do all the bits. You need to tell them the number off your old tubes. Cant say what they cost now, i did mine years ago.
Dave
Posted: Sun Feb 03, 2013 8:31 am
by maelstrom
Complete seal kit in Viton for two carbs & free shipping $50.
http://litetek.co/Carb_Kit_Yamaha_TRX850.html
You will need to buy the emulsion tubes and needles.
Posted: Sun Feb 03, 2013 8:50 am
by Con Rod
kind of useless for him then, given the needles and tubes are the parts he is looking for
Posted: Sun Feb 03, 2013 2:32 pm
by maelstrom
If the poster did want to use the Factory Pro option then I think new seals to go with the needles and emulsion tubes would be a good idea.
Sorry for not being more specific.
