CARB IDENTIFICATION
Posted: Thu Apr 19, 2012 10:39 am
by Gix
Looking at buying some new Ti needles and emulsion tubes and was told there are two types of carb for the TRX
Mine is a UK bike registered in 2001.... is there an easy way to identify which carbs I have without stripping down..I can't seem to find the ident marks
Thanks in advance :)
Re: CARB IDENTIFICATION
Posted: Thu Apr 19, 2012 10:41 am
Go to the downloads section here and look at the repair pdf, their `type` is listed there. :wink:
had a quick look:
Mikuni BDST38/2
Posted: Thu Apr 19, 2012 11:21 am
Gix wrote:Looking at buying some new Ti needles and emulsion tubes and was told there are two types of carb for the TRX
I don't believe that is correct. AFAIK the carbs were common to all models
Posted: Thu Apr 19, 2012 11:31 am
by Tarwetijger
Isn't it the TPS that switched from one side to the other?
Posted: Thu Apr 19, 2012 11:38 am
by Gix
I don't doubt you but this is what is on the Factory Pro webite
''The internet's #1 choice.
"TDM / TRX Ti ProKit"
This is "the" #1 jet kit choice of TDM riders.
Best lowend and midrange and the best, if the user / tuner tunes for it, mileage.
Uses Titanium needles. Adds more low-end / midrange, if the proper main jet is selected, more topend power. Easy to install and tune - no slide drilling.
Make float height setting easier! Pick up a Float Cage Holder for Mikuni 38mm carbs - Click here
Note
If you have a 1999 model with 40mm carbs, marked; Type BDSR38, id, this kit will not work
Posted: Thu Apr 19, 2012 12:15 pm
Note
True dat, 99 the TRX got a tad bigger carbs and 3-4 more ponies.
Posted: Thu Apr 19, 2012 1:04 pm
Killerwhale wrote:True dat, 99 the TRX got a tad bigger carbs and 3-4 more ponies.
Blimey - I never knew that. Thanks KW
Posted: Thu Apr 19, 2012 1:09 pm
by M.V.
That's news to me, very interesting. Are they better than the originals? Might be a cheap upgrade between stockies & FCR's if so.
Posted: Thu Apr 19, 2012 1:12 pm
if you want to go to bigger CV carbs, have a look at Fireyawn carbs ;)
Posted: Thu Apr 19, 2012 1:36 pm
Found that out when i bought mine -05, just checked bikez.com and it was 3 ponies....
Posted: Thu Apr 19, 2012 9:19 pm
by dandywarhol
The Japanese home market ones had different carbs with accelleration pumps - did they use the same tubes/needles? I'd guess there would be a different taper to accommodate the extra squirt from the pumps :?
Posted: Sun Apr 29, 2012 9:54 pm
by Tarwetijger
dandywarhol wrote:The Japanese home market ones had different carbs with accelleration pumps - did they use the same tubes/needles? I'd guess there would be a different taper to accommodate the extra squirt from the pumps :?
I have a set of carbs here from a Japanese model. Indeed they have something that looks like accelleration pump jets.
I will put them apart later on to see jet sizes and that kind of stuff.
Posted: Sun Apr 29, 2012 10:05 pm
by ekoja
Mine is a Japanese import and has accelerator pumps, and I fitted jets and needles for a later model Aust bike, if that makes sense.
Posted: Mon Apr 30, 2012 7:11 am
BDSR type 99-00 (and also TDM to 02 i think) should be same as carbed R1´s...found a jetting sheet 147,5 main instead of the 142 on BDST.
Posted: Sun Sep 23, 2012 10:51 pm
by dandywarhol
I don't think the TRX changed but the TDM certainly changed the carbs/gearbox ratios in '99. In fact, the post '99 emulsion tubes on the TDM can't be changed - can someone verify by part numbers that the TRX carbs changed then too???
