'04 R6 blue spots.
'04 R6 blue spots.
Post by fung » Sun Oct 09, 2011 9:37 am
I'm looking at some '04 R6 blue spots on ebay.
Good value i'm told.
Currently on the old girl i have a std master cylinder, std discs, std calipers with ferodo pads on std forks.
My question is if i put '04 R6 blue spots on std discs, and i need to upgrade the master cylinder, what can i use that will still work with the LSL levers that cost waay too much.
I'm thinking that worse comes to worse, i may be able to use the hinged lever section on another pivot casting from the 'new' model.
Re: '04 R6 blue spots.
Post by alextrx850 » Sun Oct 09, 2011 11:04 am
fung wrote:I'm looking at some '04 R6 blue spots on ebay.
heya Fung, ive got the 98 -r1 short levers on mine and the 5/8 origional master..they still work ok, really the r6 master is the one and im still looking for one
Post by fung » Mon Oct 10, 2011 9:47 am
bought and paid for...
now i wait for USPS to swing them my way.
Woo Hoo !
highlander
Post by highlander » Mon Oct 10, 2011 12:56 pm
I hope you're putting braided hoses on those ...?
Post by fung » Tue Oct 11, 2011 1:38 am
i should be able to use the TRX Goodrich lines i already have; just turn the bend in to the wheel, as per other forum goers have done.
Post by fung » Thu Oct 13, 2011 7:42 am
Found a lever compatibility chart on the LSL site.
colours = silber ..SI anthrazit ..AN schwarz ..SW gold ..GO
Yamaha
YZF 600 Thundercat 4UT alle 200-L06.. 200-R17.. 99,95 200SL06.. 200SR17.. 89,95
FZS 600 Fazer RJ02 -03 200-L29.. 200-R17.. 99,95 200SL29.. 200SR17.. 89,95
FZ6/FZ6Fazer RJ07 04- 200-L20.. 200-R22.. 99,95 200SL20.. 200SR22.. 89,95
FZ 6 Fazer S2 ABS RJ14 07- 200-L20.. 200-R22.. 99,95 200SL20.. 200SR22.. 89,95
XJ6 Diversion/ABS RJ19 09- 200-L20.. 200-R22.. 99,95 200SL20.. 200SR22.. 89,95
YZF R6 RJ03/05 99-04 200-L20.. 200-R17.. 99,95 200SL20.. 200SR17.. 89,95
YZF R6S RJ09 05- 200-L20.. 200-R35R.. 99,95 200SL20.. 200SR35R.. 89,95
Yamaha
YZF R6 RJ11 06-07 200-L20.. 200-R35R.. 99,95 200SL20.. 200SR35R.. 89,95
YZF R6 RJ15 08- 200-L20.. 200-R35R.. 99,95 200SL20.. 200SR35R.. 89,95
FZ750 1FN/2KK/3KT alle 200-L05.. 200-R10.. 99,95 200SL05.. 200SR10.. 89,95
FZX750 2JE alle 200-L05.. 200-R10.. 99,95 200SL05.. 200SR10.. 89,95
FZ8/FZ8Fazer RN25 10- 200-L20.. 200-R22.. 99,95 200SL20.. 200SR22.. 89,95
TRX 850 4UN 96- 200-L06.. 200-R17.. 99,95 200SL06.. 200SR17.. 89,95
TDM 900 RN08 02-03 200-L29.. 200-R17.. 99,95 200SL29.. 200SR17.. 89,95
TDM 900 RN11 04- 200-L29.. 200-R22.. 99,95 200SL29.. 200SR22.. 89,95
FZR 1000Exup 3LE 91- 200-L24.. 200-R17.. 99,95 200SL24.. 200SR17.. 89,95
FZS 1000Fazer RN06/RN14 01-05 200-L20.. 200-R17.. 99,95 200SL20.. 200SR17.. 89,95
FZ1/FZ1Fazer/ABS RN16 06- 200-L20.. 200-R22.. 99,95 200SL20.. 200SR22.. 89,95
YZF-R1 RN01 98-99 200-L20.. 200-R20.. 99,95 200SL20.. 200SR20.. 89,95
YZF-R1 RN04 00-01 200-L20.. 200-R20.. 99,95 200SL20.. 200SR20.. 89,95
YZF-R1 RN09 02-03 200-L20.. 200-R17.. 99,95 200SL20.. 200SR17.. 89,95
YZF-R1 RN12/RN19 04-08 200-L20.. 200-R35R.. 99,95 200SL20.. 200SR35R.. 89,95
YZF-R1 09- 200-L20.. 200-R19R.. 99,95 200SL20.. 200SR19R.. 89,95
FJ 1100 47E alle 200-L05.. 200-R10.. 99,95 200SL05.. 200SR10.. 89,95
FJ 1200 1XJ/3CW/3YA alle 200-L05.. 200-R10.. 99,95 200SL05.. 200SR10.. 89,95
XJR 1200 4PU 95-98 200-L24.. 200-R17.. 99,95 200SL24.. 200SR17.. 89,95
XJR 1300 RP02/06 99-06 200-L24.. 200-R17.. 99,95 200SL24.. 200SR17.. 89,95
XJR 1300 RP10/RP19 07- 200-L24.. 200-R22.. 99,95 200SL24.. 200SR22.. 89,95
FJR 1300 RP04 01-02 200-L24.. 200-R17.. 99,95 200SL24.. 200SR17.. 89,95
FJR 1300ABS RP08/11/13 03-07 200-L24.. 200-R22.. 99,95 200SL24.. 200SR22.. 89,95
MT01 05- 200-L24.. 200-R35R.. 99,95 200SL24.. 200SR35R.. 89,95
V-Max 06-08 200-L24.. 200-R10.. 99,95 200SL24.. 200SR10.. 89,95
V-Max 09- 200-L24.. 200-R35R.. 99,95 200SL24.. 200SR35R.. 89,95
so it looks like R6 '99-'04 or R1 '02-'03 are the best bets for a master cylinder and me keeping my LSL setup.
Re: '04 R6 blue spots./ levers
Post by fung » Wed Nov 13, 2013 12:10 pm
fung wrote:Found a lever compatibility chart on the LSL site.
Yamaha
Yamaha
