by slow codger » Thu Apr 01, 2010 12:38 pm
Bike didnt get its Mot as frame has cracked around the rear exhaust mounting point! hopefully will be sorted by next week.
Knew the horn wasnt working so had a look at that, wire had fell off!
cleaned up contacts for headlight, that works again.
Just the bloody frame!, will be having a new front tyre as well, will sort out the weeping valve at least (put an o ring in the dust cap to seal it last year)
JL
by JL » Thu Apr 01, 2010 12:42 pm
What a bummer, hope it doesn't take too much work to fix!
by Jak » Thu Apr 01, 2010 1:10 pm
That's kinda where my frame had a hole too.
Hope you get it sorted soon!! (gotta be back on the road by the 11th!!!)
by phuk72 » Thu Apr 01, 2010 1:32 pm
Picky MOT tester. Did he explain the reason for failing?
TonyDevil
by TonyDevil » Thu Apr 01, 2010 2:29 pm
i had the same thing and my old neighbour welded some new mounts for me
canne remember if i ever posted the pics....
edit: heres my old topic
http://trx850.motomaniac.net/forum/view ... =37&t=4866 no pics, will try and dig them out
TDM900 2003 - commuting tool
Z750 hardtail - project
by slow codger » Thu Apr 01, 2010 2:38 pm
Left hand mount (as looking from the back)! It moves (and widens the crack) when you pull out on the exhaust! Don't know what all the fuss is about Pete, I havent got a pillion to carry!!!. It will be sorted by the 11th, Jak (If I know where we're going).
by Jak » Thu Apr 01, 2010 4:46 pm
by slow codger » Thu Apr 01, 2010 5:26 pm
There are a lot of jokes about blondes!! Anyhow about time you got your bike on the road and rode that instead of driving down!
Red Rex
by Red Rex » Thu Apr 01, 2010 7:19 pm
Yeah, mine broke there too. Only noticed it when I was fitting the 'quiet' cans ready for the MOT.
Took it to my local Van Hire man (who races a Ducati in his spare time)
£5 minutes and £5 fixed it.
by Jak » Thu Apr 01, 2010 9:36 pm
Yeah yeah ... I know ... finally moving it next week so then all I've gotta do is learn how to fix it, fix it and get it MOT'd
Seems like it's a common weak spot on the TRXs then (I have a feeling I've said that before
Smithers
by Smithers » Fri Apr 02, 2010 5:30 am
Thanks for that. I checked my LH mount to find it had nearly departed from the subframe..... have just MIG'ed it and the paint is drying as I type..... Cheers
by slow codger » Thu Apr 08, 2010 6:34 pm
Look at the rear mount, there is a small box section between the bolts! that part is not welded to the frame! (Except it is on mine now).
Just being sprayed and drying, will be ready for Sunday.
