FCR41's don't clear out til 3000rpm?
Posted: Tue Feb 16, 2010 5:05 am
by redkiwi
Does anyone else with FCR's have this problem or is there something I should be investigating? My FCR's have the accelerator pump on them, and run fine and dandy anywhere about around the 3000rpm mark.
Re: FCR41's don't clear out til 3000rpm?
Posted: Tue Feb 16, 2010 10:11 am
(Not that I ever ride at 3,000 rpm but) mine pull absolutely fine from 2k so yes, you have a problem
you can either ride round it or get it to the dyno to rejet
Posted: Tue Feb 16, 2010 10:38 am
by redkiwi
Do your's splutter a little below 2k though?
I've already adapted my riding style to suit, though I get a few funny looks when I rev out to 3000rpm and have to slip the clutch for the first 20m. The OVER 2-1 on my bike isn't exactly quiet!
Obviously on the track/open road it isn't a problem, but motorway cruising in 5th gear can get a bit touchy, if the traffic slows down below 100kmh then I have to click down into 4th to accelerate away again.
Posted: Tue Feb 16, 2010 10:47 am
I've noticed the difference under 3000rpm after doing the tps mod setting the timing to full advance ...No quite as responsive till i get to just around the 2500mark.. Doesnt yours have and aftermarket ignition system fitted set from memory set to full advance??? Is that what your feeling :idea:
Posted: Tue Feb 16, 2010 11:47 am
redkiwi wrote:Do your's splutter a little below 2k though?
It's a big twin with flatslide carbs - they don't work under 2k
and wtf are you doing in 5th at 100kmh - you should only just be out of first :wink: Serioulsy though, all twins are lumpy at sub 2k so just change down a couple of times
do you have TPS on the carbs?
