Popping from right cylinder when cold
Posted: Fri Feb 05, 2010 10:42 pm
by Kenny
Hi Ive just reset my carbs and it now pops from cold on the right cylinder only for about 30 secs then its fine. Ive changed the plugs (back to ordinary NGK as my iridium ones lasted 10 miles). What could this be?? Ive serviced her and everything is clean and lubed. Ive also fitted new emulsion tubes from Factory Pro. What should the float heights be set to as Ive heard many heights?
Re: Popping from right cylinder when cold
Posted: Sat Feb 06, 2010 12:46 am
Here you go Kenny:
http://trx850.motomaniac.net/forum/view ... hts#p48174
(Pssst use the search facility at the top right of the forum) :wink:
Sounds like a sticking float needle to me,slight weakness of mixture.
