Fuel tank sealant ?
Posted: Fri Oct 30, 2009 6:26 pm
by G Beale
Hello everyone. I'm fairly sure I've heard of something you can use to seal minor leaks in your fuel tank by pouring it in (tank empty of course) & swishing it around then leaving it to set. Does anyone know what this "stuff" is called & know where I can buy it ?
Re: Fuel tank sealant ?
Posted: Fri Oct 30, 2009 6:37 pm
by slow codger
Posted: Fri Oct 30, 2009 6:54 pm
by G Beale
Petseal, that's the one.
Could I think of that today ? No I could not.
Thanks Dave.
Posted: Sat Oct 31, 2009 11:22 am
by Red Rex
... sounds like the sort of thing you'd use to protect your pedigree Siamese from the randy ginger tom next door
Posted: Sat Oct 31, 2009 2:58 pm
by BBB
slopped a load of that in my gpz, worked well but you have to keep moving it around for a long time. I didn't and ended up with a very hot fuel tank and a massive lump of petseal in one corner. Obvious but, do it outside as it really whiffs.
Posted: Sat Oct 31, 2009 4:53 pm
by G Beale
Thanks for all the advice folks. My office/utility room is starting to stink of petrol even with the garage door closed now so not long before the kitchen then living room start ponging too.
Tank only started leaking after I removed it & straightened the rear mount. That will teach me for trying to fix stuff that's already working.
Posted: Sun Nov 01, 2009 5:29 am
Posted: Sun Nov 01, 2009 7:27 am
by Wombat
There's also some stuff called Red-Kote that does the same deal. About to do mine soon as soon as I get the rust out.
Posted: Tue Nov 03, 2009 2:10 pm
by steve speed
all the above to my thought is only a temporary fix ,, get a fresh tank is my advice
Posted: Tue Nov 03, 2009 3:36 pm
by G Beale
Posted: Tue Nov 03, 2009 5:17 pm
by trixynut
Why not get the tank welded? If you can pin-point the leak, and its in a place that won't bee seen (heat will damage the panitjob locally) then get it welded. Or is that a big NO-NO for some reason??
As for the can, my opinion on these 'classic' bikes is they should look like they did. If they had shorter cans 'back in the day' then do it. If they didn't, don't!
Posted: Tue Nov 03, 2009 10:16 pm
by schmiffee
Ditto to Trixy. While I am partial to the shorty/stumpy muffler, on the older bikes I don't think it suits very well - I'd leave it as is mate.
Posted: Wed Nov 04, 2009 12:01 am
by G Beale
Thank you both. I will TRY to leave it alone then.
Posted: Wed Nov 04, 2009 6:22 am
shortening the muffler also ultimately effects the tuning of the bike also..
Bit like choosing the right gauge gtr strings you want to use.. You can use a std gauge all round gauge that will give you the best all round mix or a light guage that will cut right to the edge on the top end or a thicker gauge that will give you that fat bottom end sound you what...
Just as killers found out comparing his MAB system to his ACRA of late ones got the top end the others a good all round mix. Even tho it may only be the tail pipe it I'm sure it will still effects backpressure and engine response in some degree..
Posted: Wed Nov 04, 2009 12:05 pm
by G Beale
cobbadiggabuddyblooo wrote: Even tho it may only be the tail pipe it I'm sure it will still effects backpressure and engine response in some degree..
Yeah I gave all that some thought. It's probably the main reason I haven't done anything about it yet but if you saw it for real.. . . It's huge !
I'm sure 6 inches wouldn't hurt.
I use Rotopinks 9's (superlight) on both my acoustic & electric guitars.
