WIRING QUESTION
funnymachine
WIRING QUESTION
Post by funnymachine » Tue Aug 25, 2009 12:00 am
just finishing the wiring on my chop and cannot remember which coil is which colour
what colour is the wire to the left coil?
to the right?
thanks
mark
TREX CHOP https://plus.google.com/photos/11370369 ... hYfRufO6Kg
Funky little road rage
Television man is crazy saying were juvenile deliquent wrecks
Oh man I don't need tv when I gotta TRX
Re: WIRING QUESTION
Post by phuk72 » Tue Aug 25, 2009 8:34 am
can't remember off teh top of my head but there is a manual on this site - have a look there
funnymachine
Re: WIRING QUESTION
Post by funnymachine » Tue Aug 25, 2009 9:27 am
I have a manual - it just shows two different coils and doesn't really show clearly which is left or right
Can someone please take a look at a bike and tell me I would like to fire it up today :-)
Thanks
Mark
AHTHUD
Re: WIRING QUESTION
Post by AHTHUD » Tue Aug 25, 2009 12:51 pm
funnymachine wrote:I have a manual - it just shows two different coils and doesn't really show clearly which is left or right
Thanks
Mark
Im not sure it matters which way round they are. A lot of bikes work on a lost spark (where the plug still sparks on the exhaust stroke). The Japanese are pretty good at making looms where you can't really connect them up wrong IMO. I just put a new loom on my trx and didn't even notice the different colours on the coil wires, so I either got them right out of luck or it doesn't matter. I would say just connect them up and see what happens (it should either run or not).
It's all good fun till the pain sets in!
funnymachine
Re: WIRING QUESTION
Post by funnymachine » Tue Aug 25, 2009 2:34 pm
Even if it runs on wasted spark it would be in a really weird place with 270 degree crank
I have a very small battery and was concerned if I was trying to churn it over with the plugs the wrong way around it would kill it.
I tried to start it - nothing.
Switch the plug leads and BAM
Boy is it LOUD!
Good job it's on a Q plate as it wouldn't have a chance if it was being compared to a standard system at MOT time.
AHTHUD
Re: WIRING QUESTION
Post by AHTHUD » Tue Aug 25, 2009 4:57 pm
glad you got it going =D> =D> I was just lucky with mine then. Pipes only count as loud if they can reprogam pace makers at 50 yrds :twisted: :twisted:
Re: WIRING QUESTION
Post by slow codger » Tue Aug 25, 2009 7:03 pm
:shock: So what are the correct wiring colours then??
funnymachine
Re: WIRING QUESTION
Post by funnymachine » Tue Aug 25, 2009 8:57 pm
Orange on the left I think.
I'll have to go and look :-)
sportyking
Re: WIRING QUESTION
Post by sportyking » Sat Dec 10, 2016 6:55 pm
Does anyone know if "Orange on the left" is indeed correct and by left that means the cylinder on the side with the generator (left while sat on the bike)?
I have just started putting my TRX back together from a 100% strip-down and I want to connect everything correctly as I go because by the time I get to the starting it up phase in several months I will have forgotten that I took a punt on which coil wire goes where and be left scratching my head for days. Especially if I check them and find a spark present.
I am also slightly confused by the picture in the Haynes manual that shows the coil mounted on the outside of the bracket but the design of the bracket looks like it should be mounted on the inside. Anyone know which is correct off the top of their head?
nr
Re: WIRING QUESTION
Post by nr » Sat Dec 10, 2016 9:50 pm
Coils mount on the outside of the bracket. While you're in the area, check the mounting tabs for cracks. Of the four tabs on mine, three were cracked part of the way through, and one had gone completely. The coil was hanging on by a thread. I reckon the bike was about 20 miles away from becoming a TRX425 single. Easy enough to weld back on, but worth checking.
sportyking
Re: WIRING QUESTION
Post by sportyking » Sun Dec 11, 2016 10:33 pm
Cheers for the pointer on the brackets. It's just been powder coated so unfortunately wouldn't be able to see anything at the moment but will know to check later on.
nr
Re: WIRING QUESTION
Post by nr » Mon Dec 12, 2016 11:54 am
Here goes - this is what my #1 coil bracket looked like - also shows that the orange wire is to the l/h coil:
This is now all cleaned up and rewelded, and repainted. Well, I say 'welded'. What I actually mean is that I pointed the MIG in vaguely the right direction, and covered it in blobs until it kind of stuck in the right place. I'm not a naturally gifted welder.
