Jetting
Jetting
Post by Killerwhale » Thu Jun 11, 2009 8:47 am
Well, i did the 3rd dyno yesterday and i got an annoying hole in the powerband. It really get´s thin where it used to be fat.
You think i can jet myself out of this misery?? 8-[
Goes up to 15 A/F...it also as it did before go a tad fat at the end....bigger main air?
Hmmm, did some thinking.... :shock:
I´ve locked down the acc pump arm and as it now goes first fat and then thin it SHOULD help to release the arm for a later acc pump....right...!? Gotta try this tonight...
Re: Jetting
Post by cobbadiggabuddyblooo » Thu Jun 11, 2009 11:00 am
So is this cause of this problem the change of headers??? Is the slow jet and slow air jet in this range as such... Would that not give you a few options?? larger slowair jet or smaller slowjet or visa versa to compensate... or is that the best combination of jets and the result... So searching for other options
Re: Jetting
Post by Killerwhale » Thu Jun 11, 2009 11:02 am
cobbadiggabuddyblooo wrote:So is this cause of this problem the change of headers??? Is the slow jet and slow air jet in this range as such... Would that not give you a few options?? larger slowair jet or smaller slowjet or visa versa to compensate... or is that the best combination of jets and the result... So searching for other options
Chart is a full throttle run so only main jet´s involved. We have checked idle...slow...and needle and they are spot on! ~A/F 13
(you check FCR´s in approx. 1/8´s throttle up to full)
Re: Jetting
Post by Mincehead » Thu Jun 11, 2009 2:42 pm
I would agree Killerwhale,try releasing that accelerator pump,it`s on a graduated quadrant so it might pull things back in left to working as was intended.
By the way my Swedish `parcel` arrived this morning :wink: .I`m off to my home race track after 4 so havn`t had time to get stuck into the packaging yet,it`ll have to wait for my return on sunday night.
I`m in my local web cafe as I`m expecting some emails and don`t have a home pc.
Re: Jetting
Post by Killerwhale » Thu Jun 11, 2009 2:44 pm
Mincehead wrote:I would agree Killerwhale,try releasing that accelerator pump,it`s on a graduated quadrant so it might pull things back in left to working as was intended.
Good to know! Now let us know your findings...this was the first time i regret the YZF swinger change....
Re: Jetting
Post by Mincehead » Thu Jun 11, 2009 3:07 pm
I`ll confirm it`s all un-abused and intact by pm Killerwhale,cheers. :wink:
Re: Jetting
Post by Killerwhale » Thu Jun 11, 2009 3:12 pm
Mincehead wrote:I`ll confirm it`s all un-abused and intact by pm Killerwhale,cheers. :wink:
Well, i used so much packing it should a fort knox...
...or as MAX said when i shipped him a tail, "They could´ve thrown it out of the plane"
Re: Jetting
Post by Mincehead » Thu Jun 11, 2009 3:16 pm
:lol:
Yes it`s an impressive box for sure.
The sun`s just come out,been a tad damp and grey here up to now but maybe the big guy up above knows it`s the best race meeting of the year at my local track this weekend. :P
So,cheery the noo guys and gals I`m off to play. :wink:
Re: Jetting
Post by cobbadiggabuddyblooo » Fri Jun 12, 2009 3:14 am
Good luck there mate.. go hard n go fast... 8) =D> =D>
