fork rebuild
TRX-er
fork rebuild
Post by TRX-er » Sat Mar 07, 2009 9:10 pm
hello, trx-ers
does any of you have the damper rod holder(90890-01388)??
i used a piece of wood to hold the damper but when i'll get to assembly i'll need that tool...
steve speed
Re: fork rebuild
Post by steve speed » Tue Mar 10, 2009 8:58 pm
i use an air impact wrench , but sometimes you need a bit of heat as well :D :D
DOBBO
Re: fork rebuild
Post by DOBBO » Sun Mar 15, 2009 12:19 pm
I made one up by welding a bolt to a piece of 3/8 round bar like a large tee bar. If you are interested Ill dig it out and measure it up.
always expect the unexpected
TRX-er
Re: fork rebuild
Post by TRX-er » Sun Mar 15, 2009 7:45 pm
thanks! i made it by welding a bolt to a long t-bar
Overlord Neil
Re: fork rebuild
Post by Overlord Neil » Thu Oct 13, 2016 7:52 am
TRX-er, did you manage to rebuild your forks ok? I'm contemplating stripping mine down as an interim before I eventually replace the whole front end, read through the service manual and saw 'special tools'... One of them is a massive extension which seems like a simple fix to jury rig something but the other end looks like a nut blank with a small hole drilled one side and a 3/8 socket cup the other? Is there a Heath Robinson/Redneck/Bogan alternative?
As usual my problem is needing to get any work done over a weekend as I use the bike all week to commute, so I can't take it apart to have a look... well I can but that would mean even more garage time which my better half will have a dim view of!
Rubes
Re: fork rebuild
Post by Rubes » Thu Oct 13, 2016 1:10 pm
:oops: I used a wooden broomhandle and an electric impact screwdriver. Worked fine.
Re: fork rebuild
Post by dandywarhol » Thu Oct 13, 2016 5:42 pm
Electric impact gun is all that's needed. I do mine with the forks in situ
Overlord Neil
Re: fork rebuild
Post by Overlord Neil » Fri Oct 14, 2016 6:23 am
Thanks guys, I suspected the 'special tools' were nice to have. I'm guessing the function of the tool is to stop it rotating whilst you under the bolt/nut the other end, but an impact wrench shocks it loose before it has time to think about spinning?
Re: fork rebuild
Post by Tarwetijger » Fri Oct 14, 2016 9:29 am
Overlord Neil wrote:Thanks guys, I suspected the 'special tools' were nice to have. I'm guessing the function of the tool is to stop it rotating whilst you under the bolt/nut the other end, but an impact wrench shocks it loose before it has time to think about spinning?
Exactly.
Rubes wrote::oops: I used a wooden broomhandle and an electric impact screwdriver. Worked fine.
Me too. But now the misses starts complaining why the *** the broom has such a short handle :oops:
