rev limiter cutting in early
the trxtor
My TRX rev limiter is cutting in very early. I bought it as a crash damaged bike from a mate who had it lying in his garage for a couple of years, its a Japanese import , which Ive R1 forks fitted and the speedo removed. Im only goin to use it as a track bike. Does anybody know do I have to fit a cdi unit from a uk bike? Or can I link out the switch on the speedo? if so how do you do it? The speedo has 4 wires goin to it they are a brown a black a red and blue.
Cheers The Trxtor
Cheers The Trxtor
- Kayla
Re: rev limiter cutting in early
I think you can just replace the Japanese CDI with a UK one, otherwise you'll need a derestrictor thinger.
the trxtor
thanks u dont happened to know where I would get a derestrictor thingy
- honkdawillydahonk
4UN Cdi is the cheapest / easiest fix...
the trxtor
Ok Im on the look out for a 4un cdi unit
- Quan-Time
I have a 4UN CDI box here in australia.. Im not using it anymore.. BUT im still keeping it as a spare currently. If anythnig changes, im happy to send it at your expense.
If you cant find anythnig in about 2 weeks, drop me a pvt msg, i should know by then.
- slow codger
- Kayla
There's a 4UN cdi on fleabay at the minute. Do a search for 'TRX cdi' and it'll turn up, but the joker wants £60 plus post for it.
the trxtor
Yea seen that cdi unit on ebay thot it was a bit expensive!!!!
I reckon it's pretty reasonable - you tried asking Yamaha how much they are new?the trxtor wrote:Yea seen that cdi unit on ebay thot it was a bit expensive!!!!
