Couple of Noob questions
Posted: Mon Sep 29, 2008 12:12 am
Hi all,
had the TRX for a month or so now and beginning to get to know my way around it. Commuting 40k each way in traffic sure helps to accelerate the process! Have a couple of queries that I could do with some help on if I may:
The temperature never seems to get up very high. This worries me as the thermostat should open around 95C, but I've only ever seen 80C on the dial and that was when stationary in traffic. This might be ok if the temp sensor is downstream from the thermostat, but nfg if on the head side. Can anyone advise? My guess is someone's removed the thermostat for some reason...
Not the easiest thing to get to, so I want to make sure before I start investigating.
Secondly, I finally got to have a fang in the country over the weekend (while the footy was on) and didn't find the seat too comfortable. Every bump ended up being painful towards the end (barely 100k from start) wondered if the compression damping was set too hard. Can anyone give me some suspension settings to start from? I weigh about 80kG, with gear add another say 8 to 10 kilos or so.
Otherwise, I'm a pretty happy camper. Just love the torque. So much easier to overtake and work the twisties without requiring endless gearchanges.
Thanks in advance.
Thanks in advance.
