R6 Clutch Perch
Wombat
Forum Marsupial
R6 Clutch Perch
Post by Wombat » Mon Sep 22, 2008 6:12 am
Do the R6 clutch lever and perch have the same arrangement as the TRX for that little electrical cut-out switch? Only reason I ask is that I'm thinking of getting a set of either Pazzo, CRG or ASV levers, and of course they don't do a set for TRXs, so an R6 is the next viable option. It'll also give me impetus to finally fit that R6 MC that I've been holding onto for ages #-o Will you still be able to use the TRX clutch cable or would you have to use an R6 one?
Trixz
Re: R6 Clutch Perch
Post by Trixz » Mon Sep 22, 2008 7:54 am
Wombat wrote:Do the R6 clutch lever and perch have the same arrangement as the TRX for that little electrical cut-out switch? Only reason I ask is that I'm thinking of getting a set of either Pazzo, CRG or ASV levers, and of course they don't do a set for TRXs, so an R6 is the next viable option. It'll also give me impetus to finally fit that R6 MC that I've been holding onto for ages #-o Will you still be able to use the TRX clutch cable or would you have to use an R6 one?
I've done the 'switch' with a R6 (2001) mounting for the clutch lever with Pazzo levers. As easy as 1,2,3 :D
You don't need another clutch cable!
Re: R6 Clutch Perch
Post by phuk72 » Mon Sep 22, 2008 7:55 am
The answer you are looking for is ........ yes.
