Vapor dash- how accurate?
- Kayla
How accurate are the tacho and temp gauge on the Vapor dash thingy? I'm not too chewed about the accuracy of the speedo as I can't really hang on to the bike much past 100mph now it's nekkid
- Kayla
Re: Vapor dash- how accurate?
I care. Group hug?phuk72 wrote:As long as the fan kicks in, who cares about the water temp?
- steve speed
on your destruction's you will find the accuracy of the unit ,,but it should be as good or better than the original,, my fan kicks in at a indicated 104 deg
- Greg
My TrailTech is accurate for speed (against the GPS) but the ambient temperature gauge is shite so who knows... On my Katy at least I could fit the temperature sender on either the flow into the cylinder or the flow out, I still don't know which one I chose, so it rather depends on what you want to measure. I'm siding with the knowledgeable Phuker on this one.
As far as the tach's concerned I would be surprised if it was wrong...
G
G
- Kayla
Cheers all
