Headers, downpipes...etc. again!
Post by Killerwhale » Sat Jun 14, 2008 12:54 pm
So, is there any that actually has a bigger diameter than 40 so one can port the exhaust as well??
Or is it just go custom?? What is akra for example?
Re: Headers, downpipes...etc. again!
Post by youngy » Sat Jun 14, 2008 6:52 pm
well akra has an adaptor that goes into the head, then the header pipe goes into the adaptor. The inlet to the header is probably the same size as the exhaust port, not much more.
Post by Killerwhale » Sat Jun 14, 2008 7:20 pm
youngy wrote:well akra has an adaptor that goes into the head, then the header pipe goes into the adaptor. The inlet to the header is probably the same size as the exhaust port, not much more.
Yeah, but akra has those water flowed pipes dont they....kinda velocity porting but in the headers!
Post by youngy » Sat Jun 14, 2008 7:40 pm
you mean conical headers? yes.
Post by Killerwhale » Sat Jun 14, 2008 7:47 pm
youngy wrote:you mean conical headers? yes.
Think they send HIGH pressure water thru pipes when glowing red?! ...not a bad idea....wich we could have a 2-1-2 Akra! :roll:
Kevtrx849
Moderator
Post by Kevtrx849 » Sat Jun 14, 2008 9:24 pm
I'll take a measurement of my Over system so you can compare as well. Just have to wait for the sun to come up. :|
( HENRY FORD )
Post by Killerwhale » Sun Jun 15, 2008 6:28 am
Kevtrx849 wrote:I'll take a measurement of my Over system so you can compare as well. Just have to wait for the sun to come up. :|
GREAT STUFF!! Just what i wanted that is!
Kevtrx849
Moderator
Post by Kevtrx849 » Sun Jun 15, 2008 9:29 am
Over system is 43mm at the head. Glad to help. :wink:
( HENRY FORD )
Post by Killerwhale » Sun Jun 15, 2008 11:02 am
Kevtrx849 wrote:Over system is 43mm at the head. Glad to help. :wink:
Top!
....could you check inner diameter of the can as well....or outer on the end of pipework.... 8)
Kevtrx849
Moderator
Post by Kevtrx849 » Sun Jun 15, 2008 12:25 pm
No worries, i'll do that tomorrow when i get home.
( HENRY FORD )
Kevtrx849
Moderator
Post by Kevtrx849 » Mon Jun 16, 2008 7:51 am
OK, 43mm at the head. 50mm after it divides under the bike and 60mm at the can connection.
( HENRY FORD )
Post by Killerwhale » Mon Jun 16, 2008 8:01 am
Kevtrx849 wrote:OK, 43mm at the head. 50mm after it divides under the bike and 60mm at the can connection.
That really beats everything i know of....exept one offs...
Much appreciated!!
....oh crap, measurements where in the shop! :lol: :lol:
http://www.overracing.com/shop/YAMAHA-T ... 433SC.html
cheesie
Post by cheesie » Sun Jun 29, 2008 8:36 pm
how does it run at low rpm with headers so large is there a step in power at higher revs
Post by Killerwhale » Sun Jun 29, 2008 8:51 pm
cheesie wrote:how does it run at low rpm with headers so large is there a step in power at higher revs
I have the MAB system so you have to ask the Over pipe guy´s on that one...
Kevtrx849
Moderator
Post by Kevtrx849 » Sun Jun 29, 2008 10:45 pm
I reckon that the overs make the bike more rideable at low speed. Less twitchy on small throttle openings if that makes sense :roll: Power comes on good at mid range to wide open. This was true also before i fitted the FCR's.
( HENRY FORD )
