YZF front end..
Posted: Wed May 07, 2008 3:27 pm
by trixynut
Ok, anyone with one of these fitted to their 'Rex, do you know:
1. The correct oil capacity for each fork leg. I think it's 380 ml but ... ?
2. Is the speedo drive the same as on the TRX? Looks the same from a visual inspection but ... ?
Dave.
Re: YZF front end..
Posted: Thu May 08, 2008 9:38 pm
by earywig
I think the wheel spindle may be a larger diameter, Honk should be able to advise.
Re: YZF front end..
Posted: Thu May 08, 2008 10:11 pm
by youngy
Well the part numbers are different:
YZF is 4FM-25190-00
TRX is 4HM-25190-10
The bearings and oil seals also differ.
Looks like both spindles are 17mm, but 47mm dia on the YZF and 40mm on the TRX, so the YZF speedo drive may wel be a larger diameter but otherwise the same.
Hagon suggest a fork oil level of 120mm. Probably a good starting point. Volume is pretty meaningless.
Re: YZF front end..
Posted: Fri May 09, 2008 7:20 pm
by honkdawillydahonk
Fork oil capacity = 469cc (16.5 imp oz) or 464cc (16.3 Imp oz) for a YZF750SP.... Yamaha's Workshop manual says oil level to be 93mm from the top of the outer tube with inner tube and damper rod fully compressed (and no springs fitted)
Speedo drives for YZF and TRX are not the same. Use the YZF one...
Re: YZF front end..
Posted: Fri May 09, 2008 10:27 pm
by trixynut
Cheers guys, think that tells me all I need to know.
