Page 1 of 3
Increase of revs when in gear...!
Posted: Sat Apr 19, 2008 5:36 pm
Has anyone experienced this, fekkin strange me thinks.
Sometimes the revs picks up when going to first or second gear at a standstill....when going neutral it at once drops to 1200rpm.
Whatcha reckon??
Re: Increase of revs when in gear...!
Posted: Sun Apr 20, 2008 10:41 pm
by slow codger
Can you clarify whether the clutch is in, is the throttle cable sticking?, or part of carbs sticking ( thats all abit teccy for me, but crap in carbs not allowing the mechanism to close properly).
Posted: Mon Apr 21, 2008 7:07 am
I don´t have the right hand on the throttle at all....just shifting gear when standing still!
Posted: Mon Apr 21, 2008 8:02 am
by Red Rex
... when you pull the clutch in?
Is it something as simple as the clutch cable flexing and moving the throttle cable ??
Posted: Mon Apr 21, 2008 8:38 am
Red Rex wrote:... when you pull the clutch in?
No no, when putting bike into gear....one or two does not matter...
Posted: Mon Apr 21, 2008 4:27 pm
by madivi
Really misterious.
Even if the gear would influence the ECU, how would this relate to the carburetor?
I guess there is no connection at all between the two.
Could it be that your carburetor's membranes are defective (cracks)?
This can drive your idling crazy randomly (I have this on my XS).
Posted: Mon Apr 21, 2008 5:25 pm
madivi wrote:Really misterious.
Little over year old FCR´s...would think they are ok.
A mystery it is!!
Posted: Mon Apr 21, 2008 10:32 pm
by youngy
I can only think it is clutch drag
Posted: Tue Apr 22, 2008 5:42 am
youngy wrote:I can only think it is clutch drag
Wouldnt that mean a decrease in revs...
Posted: Tue Apr 22, 2008 6:07 am
by madivi
Clutch drag? Due to bearings and cogs?
How is the clutch to cause drag?
Maybe KW has a clutch with negative drag coefficient
Posted: Tue Apr 22, 2008 6:59 am
by HansJ
That's a good suugestion, gets my vote!
Posted: Tue Apr 22, 2008 7:17 am
HansJ wrote:Red Rex wrote:... when you pull the clutch in?
Öhhh, it does NOT happen when pulling the clutch. I can hold the clutch in for 10 minutes and nothing....but when put into gear....2k revs. And it don´t happen all the time.
Thinking further, this happened when going for MOT and i put the dB-killers in...fluke or not....i don´t know.
Posted: Thu Jun 05, 2008 8:31 pm
Well, this is still a problem so i bump it!
....now it got worse, clutch in the whole time....1st or 2nd=2-2500 revs.....click it in neutral and drops to 1200.
No wonder i have trouble get the gears in when riding!! ...and i thought it was the new oil....bah!
Posted: Fri Jun 06, 2008 1:51 pm
by slow codger
Ok teccy head on today, You say that it revs to 2000 - 2500 when in gear, but as soon as you put it in neutral it drops to 1200 revs. My thoughts are that you are running on choke for those high revs in neutral, so have you checked the choke cable is free. Also check the neutral wires to see if they are affecting the ECU.
Posted: Fri Jun 06, 2008 2:52 pm
I have FCR´s so no choke here...
I have very little throttle play as is so i will fix that...then i guess it´s just electrical left...!?
