does 2 into 1 go?!!!
neilb
Post by neilb » Tue Nov 20, 2007 11:00 pm
Hi guys,would there be many problems with the bike if i turned the standard 2-1-2 into a 2-1 by cutting and welding?
Post by youngy » Tue Nov 20, 2007 11:23 pm
Where would you join it? What diameter?
The stock headers are too small to go into 1 at that diameter IMO
Waz
Post by Waz » Wed Nov 21, 2007 2:28 am
This may give you some idea's. Any changes to the exhaust system will more than likely require a change in carb settings.
http://www.mez.co.uk/mezporting/exhaust_length.html
Post by Quan-Time » Fri Nov 23, 2007 4:21 am
wow, interesting link..
anyone compared a stock TRX to what that page says should be optimum ? would be instereting to see how accurate the page / yamaha are.
Re: does 2 into 1 go?!!!
Post by phuk72 » Fri Nov 23, 2007 9:47 am
neilb wrote:Hi guys,would there be many problems with the bike if i turned the standard 2-1-2 into a 2-1 by cutting and welding?
Simple answer - yes
