still need carb parts replaced with Dynojet or not ?
Posted: Sun Nov 11, 2007 6:54 pm
by pwmotorsports
So the carbs have a dyno jet kit in them am i likley to need to replace any parts in the carbs ? if so is it any more complicated by having teh dynojet kit installed ? should i just get some factory pro emulsion tubes on order ?
Posted: Sun Nov 11, 2007 7:12 pm
by youngy
no, no and check the emulsion tubes that are in there. Do you have any problems with starting?
Posted: Sun Nov 11, 2007 7:42 pm
by pwmotorsports
hard to tell at the moment what the problem is with starting but having been sat fro 3 years then ridden 15 miles then sat for a year i suspect some crap in the carbs but untill i get the plugs out i dont know if its the carbs or not
Posted: Sun Nov 11, 2007 8:34 pm
by burty
The common wearing parts in the carbs are emulsion tubes and needles.
Replace the emulsion tubes, and clean the carbs at the same time.
It's apparrently a common problem for Diapragms to split although I've never seen a split one. Might be worth investing in new ones to replace while the carbs are apart. I don't recall any parts being very expensive.
I also replaced all the screws on my carbs with stainless hex socket bolts, which makes repeated disassembly much easier.
Posted: Mon Nov 12, 2007 11:29 am
by steve speed
burty,s bang on the money ,,,do it
Posted: Mon Nov 12, 2007 8:44 pm
by pwmotorsports
but what worrys me is this on the factory pro site ?
Factory produces stock replacement needle jets / emulsion tubes for Mikuni carburetors
These Factory Pro Design "Mikuni style" needle jets are threaded for Genuine Mikuni or Factory Pro "M221 Series" main jets, but not dynojet
Posted: Mon Nov 12, 2007 8:51 pm
by youngy
There are no jets screwed into the needle jet.
Even if there were, the DJ jets would have to have the same thread as the Mikuni jets, so the DJ jets would still fit.
Worry not.
Posted: Mon Nov 12, 2007 8:54 pm
by steve speed
take no notice the thread is the same ,,they just hate dynojet ,,clue ,,both companies make dyno,s and its a big money game
Posted: Mon Nov 12, 2007 8:56 pm
by pwmotorsports
cool shall order them now
Posted: Mon Nov 12, 2007 9:06 pm
by youngy
The domed brass nut at the top of the picture is on the end of the needle jet.
As you can see there are no jets screwed into the needle jet.
Posted: Mon Nov 12, 2007 9:25 pm
by Omegaman
is changing the emulsion tubes a relatively straight forward job? and resetting the floats etc , im needing to do mine but in two minds wether to order the parts and just have a go as i do have mechanical experience but none with pertol and carbs or do i spend more money on a dealership and take my chances that the fitter has done it before
and were in the uk do i get stuff from and exactly what do i need?? and what is a waste of time changing i have looked on
http://www.factorypro.com but im based in england
sorry for so many questions
but the sooner i get it done the sooner i can go out again
Posted: Mon Nov 12, 2007 9:32 pm
by youngy
emulsion tubes is an easy job.
if you're careful you won't need to reset the floats.
straightline racing are the UK agent for FactoryPro.
do it yourself. if you feck it up, you can put it right - all for free. if the dealer does it, it'll cost you and no guarantees it'll be right.
Posted: Mon Nov 12, 2007 9:33 pm
by pwmotorsports
cool ive placed my order for them so soon as they arrive fit them i shall..........
then i wonder what else there is that needs doing............
Posted: Mon Nov 12, 2007 10:12 pm
by Omegaman
fork seal and reoil and new rear shock or rebuild if your offering ha ha
Posted: Mon Nov 12, 2007 10:13 pm
by Omegaman
oh and cheers Martin always the wise owl
daft question - There is only 2 tubes to order at £39.95 each
wat about 850 Factory Pro Stage 1.1 Carburettor kit Ti needles at £74.44?
