tdm head ?
wabbit
tdm head ?
Post by wabbit » Tue Jun 26, 2007 6:43 pm
Hi are tdm (2001)model heads the same as trx its just am thinking of getting some work done on a head but would like a standard one also :?:
(the one and only)
jpe
Post by jpe » Tue Jun 26, 2007 8:52 pm
Yes (or close enough for it not to matter)
"There is no spoon"
wicky
Post by wicky » Thu Jun 28, 2007 10:32 am
ya the heads are identical, the only enjun differences are the gearbox ratios.
Post by phuk72 » Thu Jun 28, 2007 11:37 am
wicky wrote:ya the heads are identical, the only enjun differences are the gearbox ratios.
and the pistons
and a couple of other negligable differences
billy budge
Post by billy budge » Thu Jun 28, 2007 12:53 pm
while your on the subject of tdm vs trx similarities, daft as this might sound but do you reckon the size of thread et all would be the same on the oil filler spouts????
found a filler cap that doubles up as an oil temp guage and always wanted to know what oil temps are out of interest whilst on a run, dont want the hassles of returning it if its wrong.
im pretty damn certain something that minor would be the same??
Post by phuk72 » Thu Jun 28, 2007 1:47 pm
billy budge
Post by billy budge » Thu Jun 28, 2007 4:54 pm
thanks Pete
again you are my hero man!!!!
all i need now is someone to translate that german into english so i can tell if they post to the uk or not, my german is a little rusty these days.
i wish i hadnt read that thread now because i was just starting to convince myself i didnt need fcr's for my trx but now i want them again. infact im getting desperate for a set of them and might even resort to murder for them, if you hear of a set going then you know what to do!! :D
Post by youngy » Thu Jun 28, 2007 6:41 pm
Billy....use Google Translate....works a treat!
billy budge
Post by billy budge » Thu Jun 28, 2007 9:39 pm
aahh top tip my friend, will check it out.
where would i be without you guys!!!!!!!!!!!!
Peter850
Post by Peter850 » Thu Jun 28, 2007 10:28 pm
He will reply in English , or at least Australian as he did for me .
Suncoasttrx in another world.
wicky
Post by wicky » Fri Jun 29, 2007 2:06 am
and the pistons
Hey Phuk are you absolutely 100% certain of this ?????? thats interesting as i suppose you mean the TRX has more compression ??
Post by phuk72 » Fri Jun 29, 2007 8:32 am
Yes - part of the reason the earlier TDMs make less power than the TRXs with the 'same' engine
Everyone blames the exhuast or the CDI but it's a combo of all 3
Janitor
Post by Max » Fri Jun 29, 2007 9:57 am
Pretty sure the cams have something to do with it as well, or was that already mentioned?
Post by phuk72 » Fri Jun 29, 2007 10:00 am
Max wrote:Pretty sure the cams have something to do with it as well, or was that already mentioned?
I'm not sure they are (at least for the 270 crank models)?
wicky
Post by wicky » Fri Jun 29, 2007 11:58 am
phuk72 wrote:Yes - part of the reason the earlier TDMs make less power than the TRXs with the 'same' engine
mmmmmmm i'm doubting yer statement but i know fook all !!! the 1996 onwards TDM has practically the same enjun as the TRX, oil refer to the Haynes book of lies and see if it sheds some loight on the situation. the earlier TDM's (pre 1996) are vibey as hell and quite different and do not interest me!
