Restoring compression and where to get bits these days?
Snod Blatter
Post by Snod Blatter » Sat Jan 24, 2026 7:20 pm
Hello all, long time no see. I'll post my progress on this whether you like it or not, but hopefully some of you can help me out along the way. Back in September I was happily riding around the Eifel region of Germany when I started to hear quite a loud tap being bounced back at me off the road when cornering, then a few miles later while doing about 50MPH in 4th gear uphill the bike started to slow down and I'm told quite a lot of smoke came out the exhaust. I pulled into a petrol station a few miles later and the bike sounded terrible running on one cylinder. I limped it back to the hotel and found that it seemed a lot better above 4K RPM, and at 5.5K it seemed relatively smooth. Thankfully it was the end of the holiday and, after it coughed into life on Saturday morning, I rode it all the way home to Worksop in the UK on motorways where it seemed somewhat happy. The Eurotunnel was an interesting experience but at least it got up the ramp at the exit!
I hoped it would be something simple like a hole in a carb diaphragm but they seem fine, although the plastic slides certainly rattle around in the carbs now. Finally today it was warm and dry enough to take the head off and.. well..
This is a replacement head from a TDM850 and I'm not sure what miles it has done, but I still find this a very weird failure. I've never heard of this happening on these engines before? I still have the original head with soft inlets, I may choose to replace all the inlets in that but at £60 each they aren't cheap at all. I may remove this valve and see what the seat looks like. I may just get another TDM head and use that. Not sure yet.
Thankfully the bores seem to be fine though she really chews through oil on the motorway:
The hone marks are still mostly visible though the thrust side is glazed with some small vertical scratches on the left bore. I would like to fit OEM 1.0mm oversize pistons and rings but I see these are basically unobtainable nowadays, only 0.5mm items remain and that's at CMSNL so just a few boxes of new old stock. Does anyone have any leads on finding 1.0mm items? Anywhere in the world is fine, I can wait for shipping. I'm not really interested in aftermarket high compression slappy forged jobbies, this is a road machine.
So yeah, this is where I am with it now. I'll try and measure the bores to see if 0.5mm oversize is enough, and keep an eye out for some reasonably priced inlet valves but I doubt I'll find them any cheaper. The cam caps are also a little torn up on this head so I'm not sad to give up on it. Also if anyone has a personal recommendation for getting a rebore done in the UK then let me know, I've never had to do that so far. The closer to Worksop the better, obviously!
HolerTogni
Re: Restoring compression and where to get bits these days?
Post by HolerTogni » Sun Jan 25, 2026 1:37 pm
Hi Snod Blatter!
Sorry to here that your TRX doesn't run as good as she used to.
Unluckily for you (but luckily for me) I'm not that experienced in reading valve heads or piston heads.
But they really seem to have too much residue on them - carbon (the valves) and oil (the pistons).
And out of interest:
What colour was the smoke when she started to slow down uphill - blue (= oil), black (= fuel) or white (= water)?
Hope you find the parts needed - I'll do some search, also will ask in the German forum.
Investigating greets from Munich!
Snod Blatter
Post by Snod Blatter » Sun Jan 25, 2026 3:00 pm
Cheers Holer!
They pistons do indeed have a lot of carbon on them but it is still soft, I have actually wiped a lot of it away with a paper towel and scraped the last bit off with my nail. I haven't tried this with the head but I can see if it's crispy if you'd like. On one hand I'm surprised by the amount of build up because the week away in Germany is, shall we say, "sporty" at times. But on the other hand she drinks oil on the motorway and that was the last thing she did so not that surprised really. When the oil is worn thin it can empty the sight glass in about 150 miles when sat at a steady 70, though I never knew if this is being burnt or just blown out the breather - I suspect a bit of both. It got worse over the years for sure. When running around the countryside I only have to top the oil up every 400-500 miles, still awful by modern standards (the rest of the guys find it hilarious) but quite manageable. I last changed the emulsion tubes about 18500 miles ago, I know she's a bit rich now but it's not terrible - still getting 50 to 55MPG on a run, just smells rich. The coolant came out looking fine, I don't suspect any mixing of water and anything else. The radiator was also still full to the top.
As far as I know the smoke was grey, and the loss of power was instant.
Looking on CMSNL again I see the 0.5mm oversize pistons are also sold out, only rings available. I'm sure that wasn't the case just a few days ago! So I'm completely stuck now, unless by some miracle the bores are fine and just need a hone. I can't imagine that with 53K on it.
Also if anyone knows a cheaper OEM head gasket than £89 I'm all ears. Also looking for experiences with the Athena gasket that seems to be cheaper, is it the same just without the special Yamaha sticker on it or are they a definite avoid?
HolerTogni
Post by HolerTogni » Mon Jan 26, 2026 9:51 pm
Hi Snod Blatter!
A quick search at a (in Germany / Bavaria) well-known engine repair shop has revealed that it has the parts in stock you are looking for:
https://www.scheuerlein-motorentechnik. ... rmass-1-00
Hope this helps - greets from Munich!
PS:
From memory, Athena gaskets have a bad reputation in the German forum.
Snod Blatter
Post by Snod Blatter » Fri Jan 30, 2026 1:50 am
What a great find! Do you know if anyone on the German forum has tried them? I like that the pistons can come with moly coating but they don't seem to offer any further information about them such as whether they are cast or forged, hypereutectic, whether they are guaranteed to weigh the same as OEM and generally any other info. I like that they mention the compression rings are convex though, from what I've read (mostly on this forum!) that is important because the piston rocks in the bore at TDC and square section rings will just score everything instead.
I also like that they offer a rebore service, if they are known to be good then I'd probably mail the cylinders to them. Who better to bore the cylinders than the people who supply the pistons??
Oh and I bought a genuine head gasket, thanks for that 8)
HolerTogni
Post by HolerTogni » Fri Jan 30, 2026 9:36 am
Hi Snod Blatter!
From the few people in the German forum who have own experiences with Scheuerlein, I could find no complaints.
In this connection, already at this time be reminded of the things to watch when reassembling the cylinder head if you need to - just came into my mind.
As to the questions you have regarding the pistons, maybe just write them an e-mail?
I suppose, (at least) someone there should be able to read and write English - and if not, I'll be the middleman.
Offered greets from Munich!
Snod Blatter
Post by Snod Blatter » Sun Mar 08, 2026 3:05 pm
So, a little update. I did ask Scheuerlein for further details, they told me the pistons are cast but ignored my question about them being hypereutectic. They also said that the weight of the pistons is different due to them being oversize (like it's impossible to shave off a few grams anywhere??) but this won't affect the balance of the rotating assembly (lol k).
I then fell down the rabbit hole of looking into getting my cylinders nikasil coated in a hope to follow the reliability of the TDM900 but it seems the hard chrome rings are not suitable for this, you need softer rings. I could probably source some such rings but frankly I can't be bothered with that level of faff.
After all this I finally borrowed some telescopic gauges from my dad and fitted a new battery to my admittedly cheap digital verniers, and what I found is that actually the bores are still very close to their original size, possibly even perfect. This is corroborated by the lack of any kind of lip near the top, the whole bore feels smooth near the top. There are some very minor vertical scratches but I'm pretty sure the cylinders just need a good hone and some fresh original sized rings! My next task is to try and get a ring off the pistons without breaking it and measure the ring gap, and check if there is any light creeping between the ring and the cylinder wall.
One last question, Athena base gaskets - also avoid?
HolerTogni
Post by HolerTogni » Mon Mar 09, 2026 10:12 am
Hi Snod Blatter!
There are opinions from experienced guys in the German forum that the base gasket - if still straight and clean(ed) - can be reused together with a (thin film of) gasket sealant.
The Yamaha base gasket comes with a sealant film on it.
I could not find opinions regarding aftermarket base gaskets.
"Hope this helps" - greets from Munich!
Snod Blatter
Post by Snod Blatter » Sun May 10, 2026 6:51 pm
So today I finally got back to this, thanks to it being warm enough and Yodel not delivering the bits to fix another bike.. So I thought I'd remove the pistons and gudgeon pins to inspect the small ends. And it's not good.
Left small end:
Left gudgeon pin:
Right small end:
Right gudgeon pin:
Now it was the left side that burnt the valve so I was expecting maybe a small amount of wear as it would have stayed relatively cold all the way home, but neither one is perfect. They both feel rough in the con rod and the pins feel rough if scraped with a fingernail. The pins do rock ever so slightly in the rods, though that might be normal and disappear once up to temperature?
Basically, anyone know if this is acceptable? If it's completely unacceptable then it's a good excuse to get the small ends reamed out an extra millimetre and then TDM900 pistons would fit.. There are no 900 barrel and piston sets on ebay currently but I have seen them for around £150. If such a set comes up then it's an interesting way to go, though I was hoping to not have to strip the motor so far. While I'm in there I could fit a newer gearbox too because this one is definitely tired and being a '95 model it was never good to begin with. Any thoughts welcome.
BigAl-TC
Post by BigAl-TC » Tue May 12, 2026 10:53 am
Hi,
Be carefull mixing and matching TDM900 parts Into TRX.
I believe The piston heights are different, not sure but you need to check if swapping between motors. :shock: :D
Alan.
