Fitting a single seat unit
Cloot
Post by Cloot » Sun Nov 07, 2021 1:12 pm
How do all.
I'm thinking of buying this:
https://www.ebay.co.uk/itm/324666141689
Has anyone else bought and fitted the same?
If I do get it I'm going to cut out the seat unit and use my original seat.
The one snag I see there though is how to pop the seat off, I'm thinking of drilling the seat catch and having a cable with a ring on the end is that makes any sense?
If anyone has a better idea please share it.
Many thanks, Adam
Re: Fitting a single seat unit
Post by cobbadiggabuddyblooo » Mon Nov 08, 2021 11:16 am
It’s race glass and I’ve used a couple over the yrs with Hi comp foam stuck to them for some comfort.. Just means you need to unbolt them to access under the seats.
Lot easier moulding a bit of plastic over the rear seat.
Seen 1 fella used a plastic bucket to cut one out and mould the plastic with a little heat to fit over the rear seat.
Post by Tarwetijger » Mon Nov 08, 2021 2:01 pm
Cloot wrote: The one snag I see there though is how to pop the seat off, I'm thinking of drilling the seat catch and having a cable with a ring on the end is that makes any sense?
I modified mine so that the key-switch (how do you call this) opens the driver seat instead of the pillion seat.
Post by dicky » Mon Nov 08, 2021 10:04 pm
That is a good idea.
Post by Tarwetijger » Wed Nov 10, 2021 12:52 pm
Thanks, I have those rare moments. :P
