Hi all,
I need to replace perishing rubbers on the lower joints of my 98' TRX.
Upon searching these came up...
EBAY LINK
The image shown is not of a TRX carb and also showing the airbox to carb joint, not the lower two. Are they simply the same part of different rubbers altogether?
Thanks
Carb joint rubbers (I.D please)
- Rod.s
Re: Carb joint rubbers (I.D please)
They are correct for the TRX, the sectional image is for the TDM.
I would also check that price with your local dealer as it seems high.
Thank you, I will check!Rod.s wrote:They are correct for the TRX, the sectional image is for the TDM.
- Tarwetijger
