which blue spot calipers?
Posted: Sat Aug 22, 2020 4:07 pm
by pine
Hi all,
I'm wanting to replace the pads and seals on the front brake calipers, which are blue spot. I'm just not sure which type they are.. there are the follow marks on the under-sides.. 95AN (left) 95CN (right) but aside from that, no other markings I can see..
Does anyone know which calipers these are? R1/R6/XJR1300? Does it matter?
I'm from the UK.
Thanks,
Joe
Re: which blue spot calipers?
Posted: Sat Aug 22, 2020 5:16 pm
by pine
looks like the part numbers are the same for both the R1 and R6, so looking at R1 pads and seals on that basis.
Posted: Sun Aug 23, 2020 1:15 am
by dicky
Here's a quick and dirty scrape of Yamaha online parts fiche for R6 brake pads 4SV-25805-00. OEM R1 pads have a different part number, 5JJ-W0045-00, but are the same if you buy aftermarket. Seals and pistons are used in even more models, right up to 2020 MT10AL.
Diagrams this part belongs to
YAMAHA PARTS - 2016
XJR1300 - FRONT BRAKE CALIPER
YAMAHA PARTS - 2015
YAMAHA PARTS - 2014
YAMAHA PARTS - 2013
YAMAHA PARTS - 2012
YAMAHA PARTS - 2011
XJR1300A - FRONT BRAKE CALIPER
YAMAHA PARTS - 2010
YAMAHA PARTS - 2009
YAMAHA PARTS - 2008
YAMAHA PARTS - 2007
YAMAHA PARTS - 2006
YAMAHA PARTS - 2005
FZS1000 - FRONT BRAKE CALIPER
YAMAHA PARTS - 2004
YAMAHA PARTS - 2003
FZS1000SP - FRONT BRAKE CALIPER
TDM900 - FRONT BRAKE CALIPER
XJR1300R (BLACK/BLUE - FRONT BRAKE CALIPER
XJR1300R (YELLOW - FRONT BRAKE CALIPER
YAMAHA PARTS - 2002
XJR1300P (BLACK/BLUE - FRONT BRAKE CALIPER
XJR1300P (SILVER - FRONT BRAKE CALIPER
YZF-R6 - FRONT BRAKE CALIPER
YAMAHA PARTS - 2001
XJR1300SP - FRONT BRAKE CALIPER
YZF1000R - FRONT BRAKE CALIPER
YAMAHA PARTS - 2000
YAMAHA PARTS - 1999
FZS600 (FAZER) - FRONT BRAKE CALIPER
YAMAHA PARTS - 1998
YZF600R - FRONT BRAKE CALIPER
YAMAHA PARTS - 1997
YAMAHA PARTS - 1996
YAMAHA PARTS - 1995
TZ125 - FRONT BRAKE CALIPER
YAMAHA PARTS - 1994
Posted: Tue Aug 25, 2020 6:49 pm
by pine
Thank you Dicky!! New parts arrived and fitted
Posted: Tue Aug 25, 2020 9:18 pm
by Tarwetijger
That’s allright and all, but a TZ125? Really??
Posted: Wed Aug 26, 2020 12:03 am
by dicky
a TZ125? Really??
Yes, really.
Some of the calipers are different, but the pads, pistons and seals are used on heaps of models from the TZ all the way to current models
For example, the pistons and seals are the same in blue spots and radial calipers.
The online parts fiche is a great way to hunt for parts as you can see every model that uses any particular part, as well as if it is still in production.
Posted: Wed Aug 26, 2020 8:52 pm
by Tarwetijger
dicky wrote:a TZ125? Really??
Yes, really.
Right, that makes sense. The TZ125 didn't have the bluespots yet but the pistons and seals are the same size apparently.
