Oke thanx, will start from there
Yes as far as i know it has, is the standard ecu not right?
Carb needle spacer
Re: Carb needle spacer
You can buy an Ignitech programmable ignition for the trx. ( TCIP4 2channel )
Trx spark ignition is retarded from optimum under 3700rpm to meet emissions targets and the detriment of performance.
The Ignitech and the program supplied with it has a more advanced ignition curve under 4000rpm and takes away all the snatchy, jerky feel down low and giving smoother more responsive power transitions from off/ on throttle. Much nicer on your transmission, tyre, chain and sprockets too.
http://www.ignitech.cz/en/vyrobky/tcip/tcip.htm
