Thanks mate, but seems to be running OK since I've run it up to operating temp.
Top end rebuild is my project for NEXT winter. This winter I just want to get the basics done and see if I bond with it.
Inlet Cam stuck solid
Re: Inlet Cam stuck solid
Hi where did you get the o rings from they are £10 each from Yamaha
- SDN
Not anymore - I have done the broom handle sanding trick - worked fine for meSDN wrote:I do have a spare cylinder head going - for a small consideration if you're interested
