gainz
by gainz » Sat Jun 10, 2017 7:14 am
Gday all!
Just a quick query, about to replace my stock engine with a grey import from the wreckers... Any compatibility issues between the two that I should be aware of? Bottom end is gone in mine but Its my spare trx so slowly building it back up
If anyone happens to have a good engine in Australia let me know ...the wrecking yards are hard work!
Thankyou!
by cobbadiggabuddyblooo » Sat Jun 10, 2017 7:47 am
Most grey imports are pre 97 so good chance you'll have to address the inlet valve issues.
If your head and cam bearing surfaces are ok on you Aussie TRX ( as long as it's 97 onwards) you can swap the heads around at the same time.
