Which master cylinder have I got?
Posted: Wed Mar 15, 2017 10:47 am
by Spiky
Is there an easy way of telling which master cylinder I have?
The bike has blue spots and braided lines, but the braking brings a whole new meaning to the word 'wooden'. It stops, but without any feeling whatsoever.
Ideas?
Re: Which master cylinder have I got?
Posted: Wed Mar 15, 2017 7:57 pm
by Snod Blatter
The bore size will be written into the casting of the master cylinder somewhere, quite a large font and in a circle. The stock item is 5/8.
Posted: Thu Mar 16, 2017 2:58 am
by dicky
You should have the 14mm master cylinder that is standard for all Blue/Silver/Gold R6/R1 calipers.
The 5/8 will work, but it will feel a bit wooden.
Hmm...
Posted: Thu Mar 16, 2017 10:51 am
by Spiky
Snod Blatter wrote:The bore size will be written into the casting of the master cylinder somewhere, quite a large font and in a circle. The stock item is 5/8.
Dang - you're right! Good work that man!
Posted: Thu Mar 16, 2017 11:55 pm
by Spiky
Indeed.
And therein lies my problem.
Do the 14mm Master cylinders typically come with the reservoir attached as a part of the unit (as oppose to the remote reservoir that I currently have on my TRX)? I'm currently looking at one from a 2005 FZ6.
Posted: Fri Mar 17, 2017 4:16 am
by alextrx850
The size of the master cylinder is on the inside ..or next to the handle bar its bolted to.
Posted: Fri Mar 17, 2017 8:14 am
An `example` of what you need for your blue, silver or gold, non radial spot calipers:
http://www.ebay.co.uk/itm/YAMAHA-YZFR1- ... SwdzVXkPUH
