found this in the oil..
techfurby
so after giving the bike a new cam chain and tensioner on first start up get a loud tapping sound over the engine idle..ran fine and held idle... so switched off and disconnected the left cylinder spark plug..bike ran awful but no tapping sound..
then decided to plug spark plug back in and start up..
a minute the bike ran perfect sounded great with the staintune pipes. all of a sudden get a rattle from motor.. its at engine speed. you throttle on it gets faster. so decided to pull exhaust off and sump and bang..find this copper looking shavings..
https://drive.google.com/file/d/0B5Ymln ... p=drivesdk
now the question is its clearly a bearing of some sort. any one else had this???
maybe anyone know of any spare motors or wrecking bikes in south australia.
Re: found this in the oil..
When you started the motor , did you find you had an oil feed to the top of the motor via the bleed bolt on the exhaust cam pushing oil out when running????
techfurby
you mean like a hose not connected? everything seemed to be connected and no oil was leaking
techfurby
and no oil out any of the breathers.
The small bolt with a copper washer that screws into the head positioned on the Cylinder 1 end (LH end) of the exhaust cam oil galley.
This is used as an inspection opening to see you are getting oil pressure up to the head and cams.
When you first start the bike you can remove this bolt and should see a slow feed of oil running out of the bolt hole.
If it's an oil pressure issue that has caused this damage since dismantling to replace the cam chain, I'd start by looking to see if the oil pump is doing as it should.
techfurby
ok cool thanks for advice..so i should in part put sump back on fill it up and see?? or just take it to mechanic and see what they say?
techfurby
now what parts should I need to get this going again. sounds stupid I know but it shouldn't have damaged the top end at all should it? the bike runs nice and smooth just rattles.
I'm asking because 2 mechanics have said scrap the motor and get another..(can't find a second hand motor complete in south australia)
if I was to get either second hand crank or mine reground and balanced and new bearings thats all they are going to do? any other parts that would need to be done?
would it of damaged anything else internally?
Capau
If there is a rattling sound, you should find this sound disassembling engine step by step. There is no other way to find out what you will need for repair.
You don't cure your teeth by phone, do you?
techfurby
no i normally wait till they fall out and mince all my food
Capau
techfurby
so today my uncle came around and we started looking at the bike. ran it afew times listening with a stethoscope. we cannot pin point the noise it's making. he listened to the bottom end and he said it was quiet running smoothly.the noise seems to be intermitient aswell. he said the bike is running smooth and seems healthy..but we can't work out where or what to look at to solve the proberlem.would like to rule out every Avenue before we split the case.
Have you had the oil pump apart? It`s simple to do but if you do it and check the rotor n housing and find scoring it`s definitely time to split the motor.
Think about something you've left loose in the whole tear down and fit up.techfurby wrote:so today my uncle came around and we started looking at the bike. ran it afew times listening with a stethoscope. we cannot pin point the noise it's making. he listened to the bottom end and he said it was quiet running smoothly.the noise seems to be intermitient aswell. he said the bike is running smooth and seems healthy..but we can't work out where or what to look at to solve the proberlem.would like to rule out every Avenue before we split the case.
If it's intermittent.
Engine mount bolt rattling or so.
Coupled to the debris found in the oil, it sounds like the start of a left side big end bearing failure. Removing the left plug lead removes the load from the bearing and silences the knocktechfurby wrote:so after giving the bike a new cam chain and tensioner on first start up get a loud tapping sound over the engine idle..ran fine and held idle... so switched off and disconnected the left cylinder spark plug..bike ran awful but no tapping sound..
techfurby
quote for a new motor from nsw was $1100 delivered. but 87thou on the clock.
