Thermo fan cut in temp
Posted: Sun Dec 18, 2016 5:35 am
by Trev850
Hi
Does anyone know what temp the fan should cut in?
Ive fitted a new thermo fan switch fan still not cutting in, bridge the terminals fan is fine,
Re: Thermo fan cut in temp
Posted: Sun Dec 18, 2016 6:50 am
by Con Rod
about 105 degrees, trx runs pretty cool generally so you will probably never have it come on unless you are stuck in traffic on a hot day
Posted: Sun Dec 18, 2016 7:47 am
by Trev850
Just found the manual on here it should cut in at 98c and turn off at 105c. Would of thought 98 was a bit high
Posted: Sun Dec 18, 2016 2:08 pm
by Red Rex
You have to remember that it is a pressurized system and water boils at a higher temperature under pressure (ie Not at 100°C) :)
Posted: Mon Dec 19, 2016 9:15 am
http://www.ebay.com.au/itm/171021892711 ... EBIDX%3AIT
Here is a thermo fan switch that I used on my TRX.
Cuts in 10* earlier at 95*c and off at 85*c
You just need to make up a terminal adapter to fit into the 2 smaller female terminals on the loom to the 2 larger blade terminals on the new switch.
Simple and very easy job....
Good if you have to deal with city stop/start traffic on your day to day rides especially in the Ozzie summer.
Posted: Mon Dec 19, 2016 12:19 pm
by Ragnar
Posted: Mon Dec 19, 2016 2:54 pm
Yer that's the jobbie :wink: :thumbright:
Posted: Mon Dec 19, 2016 8:07 pm
by Ragnar
Copycat :oops: :D
Posted: Sun Dec 25, 2016 9:49 am
by SDN
I replaced mine with a lower temp item, as with tuned engine I was bit worried about overheating - the engine really chucks out the heat on a hot day in traffic, it's like hugging a wood burning stove!
