Oil sight glass slighly gunked up
Posted: Tue Aug 23, 2016 1:08 pm
by Rubes
Oil sight glass is starting to get a bit hard to see through with a slight brown sludge stain. Bike has done about 145,000km. Runs ok but checking oil level becoming a bit of a pain. Should I look at using some form of engine flush, a diesel oil or just leave it to avoid making a small issue worse by loosening up potential sludge? I'm thinking leave it alone but any thoughts?
Re: Oil sight glass slighly gunked up
Posted: Tue Aug 23, 2016 1:33 pm
You `might` be able to fashion a wiping tool from welding rod, gaffer tape and a cotton bud.
Posted: Wed Aug 24, 2016 2:35 am
by Rod.s
Rubes wrote:Oil sight glass is starting to get a bit hard to see through with a slight brown sludge stain. Bike has done about 145,000km. Runs ok but checking oil level becoming a bit of a pain. Should I look at using some form of engine flush, a diesel oil or just leave it to avoid making a small issue worse by loosening up potential sludge? I'm thinking leave it alone but any thoughts?
I'd run a quality oil clean through the engine as that sludge is all through the engine and will reappear even after you wipe it away…….and a new filter after cleaning
Posted: Wed Aug 24, 2016 11:39 am
by drix
Or you could remove the upper oil sump cover to clean the glass, replace the seal and fit back on. A full oil flush + a new filter and you'll be good for another 145000kms!
