Hit starter, "click" then dash lights go out.
WR450FGreg
Post by WR450FGreg » Fri Jun 24, 2016 5:30 am
MY TRX has sat without being ridden for a couple of months.
It has a battery that is probably 4-5 years old, which cranked the motor over just fine last time I rode the bike.
I went to start it yesterday. The dash lights all lit up as per usual, I hit the starter button, there was a "click" sound from the seat area and the dash lights all went dead. (The bike didn't start.)
I pulled the seat off to check fuses, all of which appear fine.
I then took connections off, then put them back on to check for dodgey connections.
After I took the grey one (see photo) off and put it back on the dash lights all worked again, but once again, as soon as I hit the starter they all went out and there was a "click" from the under-seat area.
Any ideas guys?
Any advice will definitely be taken on board and considered!
Thanks in advance,
Rod.s
Re: Hit starter, "click" then dash lights go out.
Post by Rod.s » Fri Jun 24, 2016 9:00 am
Your battery is dead….
Post by alextrx850 » Fri Jun 24, 2016 10:23 am
Yep..
Excalibre
Post by Excalibre » Fri Jun 24, 2016 12:26 pm
yep...
I suggest replacing it with a Lithium Ion battery. Incredibly light, more cranking power and holds it's charge for a year or so without needing to be recharged.
e.g. http://www.ebay.com.au/itm/SSB-LFP14H-B ... xySFJSFvSe
Post by cobbadiggabuddyblooo » Fri Jun 24, 2016 12:50 pm
I'll agree on the lithium ion.
The std 210cca Lithium ion battery for a TRX is small and light with more than enough power on tap.
Bought a heavier duty Shorai with 270 cold cranking amp for the higher compression and still weighs in just on 1 kg so you'll loose around 2kg + just in battery weight.
It sat on the bench for over 1 year before I finally fitted it from new and after running it for a couple of months it sat on the bench again for another 12 months and no issues with power loss. Best investment for weight saving and longevity.
Rod.s
Post by Rod.s » Fri Jun 24, 2016 1:17 pm
alextrx850 wrote:Yep..
Elegantly understated as always Alex….
Post by alextrx850 » Fri Jun 24, 2016 10:04 pm
Ha ha,..yes, that's about it these days Rod.
I remember back to the old days pre fuel injection and my duties as an apprentice panel beater was to start all the cars and move them out of the shop for the day's work to start.
Still do as the now apprentices don't show for work on time or standing outside the gate smoking and texting each other. :roll:
I get the feel for each start
WR450FGreg
Post by WR450FGreg » Sun Jun 26, 2016 9:47 pm
Aaah shit! ......
sorry guys, I just realised that I left one important piece of info off that initial post. (Doh! #-o )
At first I thought: "Flat battery for sure".
I stuck the charger on it and it was indicating that it still had a fair charge, not full, but definitely not flat either.
I charged the battery up to full charge overnight regardless, so I doubt it's the battery. Maybe I'm wrong?
Post by ekoja » Mon Jun 27, 2016 1:08 am
Its the battery.
Rod.s wrote:Your battery is dead….
Humour us, put a fresh battery in and see if it starts!
Excalibre
Post by Excalibre » Mon Jun 27, 2016 9:05 am
ekoja wrote:Its the battery.
Yep... :wink:
Post by alextrx850 » Mon Jun 27, 2016 9:55 am
:lol: :lol: :lol:
baptie0
Post by baptie0 » Mon Jun 27, 2016 10:52 am
Battery earth to frame lead can cause the issue you describe.
Rod.s
Post by Rod.s » Mon Jun 27, 2016 1:04 pm
the battery can hold a good 12/13 volt but have no/low amp's
WR450FGreg
Post by WR450FGreg » Mon Jun 27, 2016 8:16 pm
Thank you for the useful responses. :wink:
Post by alextrx850 » Mon Jun 27, 2016 9:15 pm
Sharing the idea of solar trickle chargers to bikes that don't run regularly.
Available in good auto suppliers and not that expensive when they can be used on the car as well.
Same as the wife,..a looked after battery is a happy battery.
