It came time for this story to be completed..
Lets continue from the point we previous interrupted. The crankshaft is clamped in the vice.
Wash the brown sludge:
Little painting attempt:
The new connecting rod for piston in cylinder 1:
All journal bearings and connecting rod bearings are new.
All gaskets also new.
I had to realize (for the cost of 90USD) that the used cylinder block i purchased will not help, it also had wear.
Worn in (+) as my original cylinder block.
I saw no other decision, but go for 858,8cm3, oversize 1 (+0,5mm) over normal, new pistons and rings.
At the photo below, a stamped "50" on the top of the piston is seen. Not found at "normal" pistons, reserved for oversize pistons.
Same "50" at oversize rings. Normal rings do not have such digits there, only the markers for "top side" - T.
New parts have protective plating, dark gray. The old wrist pin is the shiny one.
The red is Loctite 518, anaerobic acrylic flange sealant (Cobba's invention in this engine). The factory sealant was gray silicone.
Had some little confusion until i coupled properly the crankshaft and the balance shafts.
The marker "arrow" points to "left" side of the woodruff key slot. Its Haynes manual that helped, thanks to a friend who knew this fact.
had to support the balance shafts with some carton pieces to stand still as i am coupling them to the crankshaft:
Did assembled pistons and cylinder block to conrods by the easiest way for myself. With pistons preliminary inserted.
Video from "almost" first start of the rebuilt engine:
https://rednikmarto.info/tdm850service/2022/after_first_start.mp4
In the night of 15 Oct to 16 Oct did short but intensive run-in.
Did also the first oil change at about 20 miles.
This is with the new oil:
Thanks to TRX forum members for sharing knowledge!
Thanks to the local professional workshops for the head service and cylinder block machining.
Happy End of the story.
Sold to an ex-colleague, who recently become a motorcyclist.
