My baby is sick - part 2
Posted: Thu Feb 22, 2007 10:01 pm
by Steelback
As you can probably tell I am not a mechanic so dont know much about engines but if my TRX is running too rich could I damage the valves and pistons/
Re: My baby is sick - part 2
Posted: Thu Feb 22, 2007 10:36 pm
Steelback wrote:As you can probably tell I am not a mechanic so dont know much about engines but if my TRX is running too rich could I damage the valves and pistons/
Other way around, lean condition and your valves wont like it!
....rich and you will see a lot of black crap (as i have) in head outlets.....god knows i need a headjob! Jak??? (sorry, could´t help it....)
Posted: Thu Feb 22, 2007 10:39 pm
Simple answer is yes - the lubrication of piston, piston ring and cylinder bearing surfaces becomes increasingly ineffective.
However, you would have to be running way rich too cause any serious problems.
What makes you think the bike is running rich?
Posted: Thu Feb 22, 2007 11:06 pm
by Steelback
Using a lot of fuel - running rough under 3000 rpms
Posted: Fri Feb 23, 2007 6:18 am
Steelback wrote:Using a lot of fuel - running rough under 3000 rpms
Have you tried running it without the "snorkel" in airbox?
Posted: Fri Feb 23, 2007 8:00 am
by cheap_trix
Doesn't the snorkel hold the airfilter in?
Posted: Fri Feb 23, 2007 9:20 am
And this is after replacing the emulsion tubes? What main jets are you running? What is a lot of fuel - how many miles to a tank full?
Can you whip the plugs out easily and post a pic on here?
Posted: Fri Feb 23, 2007 10:04 am
by dillthedog
check all them rubber hoses around the carbs
same symptoms as mine pull the throttle back under 3000rpm and it farts pops and no pull just 1 hose had a restritive kink in it re routed it and it was a instant fix hope this helps
Posted: Fri Feb 23, 2007 12:47 pm
by Steelback
Cant see any kinks in hoses - went out at weekend with full tank and did 60 miles and she went on reserve. Think the last owner has dynojetted it, I havnt done anything to the carbs - would it be easy to get carbs back to factory spec if so how and what would I need ??
Posted: Fri Feb 23, 2007 1:40 pm
by Quan-Time
running rich increases the risk of burning out your exhaust valves (rare) but most likely burning out you exhaust headers.. To the point of making them glow red hot..
If they dont glow, your fine.. Too rich means excess fuel, which also burns in your exhaust, and thus, burning on the WRONG side of the valve.. which is bad.
but as others stated, bad lube, wrong temp conditions (its actually a colder burn, lean is WAY hot) etc...
simple tuneup via your local mechanic should be fine.. like a 10min job to get it properly ratio'd...
Posted: Fri Feb 23, 2007 7:43 pm
by Steelback
Thanks guys
Posted: Sat Feb 24, 2007 11:22 am
by idl1975
Steelback wrote:Cant see any kinks in hoses - went out at weekend with full tank and did 60 miles and she went on reserve. Think the last owner has dynojetted it,
The dynojet kit would have contained special needles and needle clips, and a selection of main jets. The needles are DJ specific, but the main jets are simply stock Mikuni items.
To return your bike to stock would therefore mean going back to the original main jets (140 jets, I believe) and original needles. Haynes manual will tell you what to do. I would also pull the plugs and check that they aren't fouled.
Note that if your bike has race exhausts on it, going back to stock jetting will have it running very lean. Probably not a good idea, although TRXs are supposed to run rich at high revs in stock form.
However, if you are sure it is not the hose problem previously discussed (as the symptoms are v. similar), then I would suggest that emulsion tube wear is by far the most likely culprit for an overfuelling problem like this. Just replacing the DJ kit parts with stock won't cure that, since DJ kits don't change the emulsion tubes in the first place.
A clued-up Yamaha mechanic who knows his or her TRXs will probably include the emulsion tube issue in the list of possible causes, but I worry that if you get someone who doesn't, they will put the problem down to a bad carb setup by the last owner, rejet the bike, and the problem will then recur in short order. If you don't want to do the work yourself, suggest you at least check that the mechanic who does it understands that emulsion tube (a/k/a "needle jet") wear is a potential cause that should be looked into.
Posted: Sat Feb 24, 2007 8:59 pm
by Steelback
Great
thanks for the info will get it properly checked out
Posted: Fri Feb 29, 2008 1:44 pm
by Steelback
Sorted - carbs out and back in and out again - mechanic was about to throw them at the wall when he noticed a small hairline crack in one of the floats - put in new one - bike running perfect now
Posted: Sat Mar 01, 2008 1:24 am
by Shifty
Killerwhale wrote:god knows i need a headjob! Jak??? (sorry, could´t help it....)
Maybe I can help????
