Page 2 of 3
Re: Popping from exhausts on overrun - NOW SORTED!
Posted: Sun Jul 05, 2015 11:12 am
Yes I think looking at 3 D printing it is a smart idea.
If you can do it cheap, there is bound to be a market as the Mikuni carbs are used on multitudes of bikes.
Once the words out on a few forums you may be on a winner..
Posted: Tue Nov 03, 2015 12:38 pm
by torino68
Yet again this forum proves invaluable. Had the same problem and assumed it to be a leak somewhere in the exhaust so re-sealed and tightened everything with no change to problem. Checked and read this post and checked - my right hand carb had exact same cracking in this plastic cover, so have glued that up temporarily and bike now runs perfectly.
Now - has anyone got a standard carb or set of 2 they want to sell which has/have these covers in good condition (no cracks or perishing) ?, preferably in South East Qld to save postage. Let me know, thanks.
Posted: Tue Nov 03, 2015 1:40 pm
There was a seller on ebay in Italy that had 10 or more sets of NEW 38mm Mikuni carbs to suit Trx/Tdm/xtz and various ducati's that use the same carbies.
The only difference with the Ducati pair would be the throttle cable/link pulls from a different angle.
That and any primary jetting difference can be taken from your originals.
The needles and emulsion tubes are the same...
They where about $220 shipped to Aust for the pair of new carbies.
Do a bit of a search on ebay, world wide you he may still have a set or 2.
http://www.ebay.com.au/itm/301767136673 ... EBIDX%3AIT
Posted: Thu Nov 05, 2015 8:00 am
by johno440
I have a used set availabl which I've only taken the TPS off. I'm in Burpengary. PM me if interested.
Posted: Thu Nov 05, 2015 9:32 pm
by dandywarhol
cobbadiggabuddyblooo wrote:There was a seller on ebay in Italy that had 10 or more sets of NEW 38mm Mikuni carbs to suit Trx/Tdm/xtz and various ducati's that use the same carbies.
Also don't have the coolant or appear to have the TPS facility either - still cheap carbs
Posted: Fri Nov 06, 2015 2:09 am
Yes 99% of the internals would be generic including that white plastic thingo that seems to be the gremlin people are finding of late.
Can rebuild your carbies with your own body or chop n change throttle/TPS set up..
Posted: Sat Nov 07, 2015 9:55 am
by torino68
Thanks for the replies guys. Johno440 - I tried to send a PM but I don't think it worked. Haven't done one before so no doubt me not doing it correctly.
Posted: Sat Nov 07, 2015 10:02 am
click on your messages on top left of page.
On that page you will see a section on the left ... OPTIONS
have a look on the out box or sent messages to see if successful..
Posted: Sat Nov 07, 2015 10:34 am
by johno440
Call me tomorrow 0466 554544
Posted: Mon Nov 09, 2015 11:26 am
by pom in nz
thanks guys, had the same backfiring from my bike, so I just painted the plastic thing with black smooth rite
now shes all good
Posted: Fri Mar 25, 2016 10:32 am
by Ruste
So did anyone work out where to get a new Air-Cut Valve Cover from in Aus?? I need one too. Have glued mine up but really want to replace it.
Posted: Fri Mar 25, 2016 10:50 pm
by alextrx850
Ruste wrote:So did anyone work out where to get a new Air-Cut Valve Cover from in Aus?? I need one too. Have glued mine up but really want to replace it.
ID just make one myself.
You could always buy one from KEDO Ruste.
Sixth post down on page one,this topic.
Posted: Sat Mar 26, 2016 1:54 pm
by pbear62
I don't know that you could make them yourself - if you look really carefully on the inside of the offending
plastic part you can see a tiny air passage which would be required to operate the diaphragm.
I don't know if you could replicate this - if it was just a plain solid disc it would be easy ....
Andy
Posted: Mon Mar 28, 2016 11:42 am
by Ruste
Thanks Alex. Was hoping not to pay the stupid amount of freight quoted. Will ask a friend if he thinks he can 3D print it for me. If not I'll annoy Kedo Australia or pester some wreckers.
Posted: Sun Apr 17, 2016 1:47 am
by nicosauraus
Hey all. Brand new Rex owner from NZ. Having the same issue, bad popping on overrun. My bike has been fairly modified by the previous owner into somewhat of a cafe racer style including megaphone exhausts. These are very minimal on the baffling and noise reduction, oooooh they do sound good though!! I don't seam to have the same issue with the cracked plug on the carb but am wondering if it's caused by the megaphones and their lack of baffling? I have read this can cause the same issue. I ride her everyday as my main mode of traffic avoidance so before I start stripping and diagnosing I want to try rule out the mufflers. Any light shed would be much appreciated!
