Popping from exhausts on overrun - NOW SORTED!
Re: Popping from exhausts on overrun - NOW SORTED!
Post by dandywarhol » Sun Apr 17, 2016 11:41 am
Welcome to the forum. First make sure your pipes and silencers are totally airtight at the joints
Post by cobbadiggabuddyblooo » Sun Apr 17, 2016 12:40 pm
Unbolt the exhaust and run a little roof n gutter sealant around the headers going into the head and where the megaphones bolt on. Give it 45-1hr to dry and see how you go.
You can have a quick Squiz to see if the copper exhaust gaskets in the head are ok while at it.
Rod.s
Post by Rod.s » Tue Jun 21, 2016 7:39 am
Just in…Air cut out valve from KEDO Aust, $27.40 delivered, Part number 28211. Order from the Kedo Aust web site :wink:
http://www.kedopartsaustralia.com/searc ... uery=28211
remi1au
Post by remi1au » Wed Jun 17, 2020 1:19 pm
I know this an old thread, and I don’t visit very often, but once again this site has proved invaluable. I had this issue for a few months now and was scratching my head trying to figure out what was causing it. A bit of epoxy on the plastic cover and problem solved. Thanks guys.
