Reducing the reach... handlebars or clip-on risers?
- pwmotorsports
- pwmotorsports
Biffidus
Damn, that would be perfect but it's on the wrong side of the world!martin young wrote:similar here and cheap too!!
Can anyone tell me what those things are called so I can search for them? Google translates the description to:
The set contains:
Superbikelenker in blue from LSL
Fork bridge of MFW
Extended Stahflexleitungen
Retaining screw for the brake fluid container
Longer hose between brake fluid containers and the brake pump
Partial appraisal for steering wheels, fork bridge and Stahlflexleitung
- CULater
Biffidus wrote:Damn, that would be perfect but it's on the wrong side of the world!martin young wrote:similar here and cheap too!!
The set contains:
Superbikelenker in blue from LSL = Steeringbar from LSL
http://www.lsl-motorradtechnik.de/php/index.php
Fork bridge of MFW = yokes from MFW http://www.mfw-wolf.de/
Extended Stahflexleitungen = steelbraided brakelines from Stahlflex
Smoke Tyres Not Drugs!
http://media.putfile.com/Smoke-Tyres-Not-Drugs-26
Mr Supplements
Max wrote:Not as long as it's torqued down properly (tight). I've done umpteen hours at the track with mine, never a problem.
Notice where they are in this pic.
And I have the left pulled in slightly more than the right because of my busted up shoulder. No stinkin M6 bolts in there.
Max what fairing and belly pan are you using? It looks great!
- Jak
You both are
Just a matter of a "space" .....
Twins on a TRX site
(PM'd you both by the way)
Twins on a TRX site
Mr Supplements
- Jak
OK - name changed as per requestRedRex wrote:LOL don't get too upset mate it's only a name and besides admin are going to change it.
Maybe admin need to configure the registration script a bit differently so this doesn't happen.
As for the suggestion about registration - not sure that's possible (I'm sure Max will answer this bit too). What I will say is that with the number of new sign-ups every day it'd take up too much time to manually check against existing users (especially with my memory
- slow codger
- Max
- Janitor
It's an R6 (2002 model, I think...) glass race fairing. The belly pan is part of it. Couldn't get them to stretch enough to make it a full fairing.Mr Supplements wrote: Max what fairing and belly pan are you using? It looks great!
BTW concerning scripts... If you've got one, I'm all ears. If there's one thing I hate more than changing oil, it's writing script...
Mr Supplements
Man I know I run my own website and try and do all the work on it myself. Java and php can be a real challengeMax wrote:It's an R6 (2002 model, I think...) glass race fairing. The belly pan is part of it. Couldn't get them to stretch enough to make it a full fairing.Mr Supplements wrote: Max what fairing and belly pan are you using? It looks great!![]()
I think the half fairing and belly pan look a treat.
