Rear shock body
- G Beale
Rear shock body
The shock itself is anodised ally yes ? So if I polish it up nicely it will inevitably go furry, dull & corrode yes ? What can I do to prevent this before it goes off to be rebuilt or even whilst it's in use on the bike ? Don't wanna paint it now I spent so much time polishin.
Re: Rear shock body
Lime blocks are the norm for protecting polished alloy but I do happen to know that acrylic polymer sealants now get used a lot too.
it`s like using wax over a polished painted surface,helps to seal the shine from attack by further oxidisation.Oxidisation is the aging process that pretty much everything suffers from in one way or another in the presence of oxygen,even the cels of living tissue!
Aluminium alloys are protected by their own natural layer of oxidisation,if it wasn`t there the material would deteriorate quickly through more extreme oxidisation.
Here`s a wee `learn about aluminium` link for you,personally I find metallurgey fascinating:
http://en.wikipedia.org/wiki/Aluminum
- G Beale
Re: Rear shock body
Nice one Geoff. All I've got to hand are a few tins of cellulose clear lacquer which will probably peel off as soon as I look at it.
Would this polymer stuff be the same as the acrylic resin used in the process of making carbon fibre or glass fibre components ?
Re: Rear shock body
It`s a wax/liquid polymer that basically `seals` and protects the item coated/waxed from oxidisation,it`s not a coating that hardens as such(like a resin/varnish).
This might help explain it:
http://detailingwiki.com/index.php5?tit ... ifferences
Try contacting this outfit for guidance and products:
http://www.polishing-kits.com/
And here`s their polishing guidance page with reference to Vienna lime powder for `finishing` polished surfaces and also Belgom-Alu which is readily available from many motorcycle dealers and specialist suppliers like M&P:
- G Beale
Re: Rear shock body
Stuff it I've painted it now.
Re: Rear shock body
AHHH so wax stops the ageing proccess..mmmm..so those people that tie their partner to the bed and drip hot candlewax all over them are just trying to slow the aging process down OHHH OK ... THANKS Mincehead...Learn something every day... No wonder mum and dad looked so yound for an 80yr old couple
Re: Rear shock body
maybe we sould change the name of this thread to REAR BODY SHOCK...
- idl1975
Re: Rear shock body
Remember the movie "Goldfinger"? That "young" woman was actually 97 years old, but perfectly preserved. You thought they made that up, didn't you?cobbadiggabuddyblooo wrote:AHHH so wax stops the ageing proccess..mmmm..so those people that tie their partner to the bed and drip hot candlewax all over them are just trying to slow the aging process down OHHH OK ... THANKS Mincehead...Learn something every day... No wonder mum and dad looked so yound for an 80yr old couple
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
'76 TY250.
- steve speed
- G Beale
Re: Rear shock body
I think it nearly was called cod-finger but they deleted those scenes before it went public.steve speed wrote:gold finger ?? i thought it was called codfinger![]()
Cod-member.
What was this thread about again ?
- Jak
Re: Rear shock body
Well you started itG Beale wrote: What was this thread about again ?
Re: Rear shock body
Always new mum and dad where up to something fishy but never smelt like cod...
