Ahh, sorry....it was in the post just under here "jetting - dyno result"dfh wrote:Maybe its a language thing but I cannot see in any of your posts the rear wheel figure your dyno operator gave you for your bike. BTW were did Phuk say it was knackered?Killerwhale wrote:"in your reluctance to cough up the figure your bike produced"
...It´s all in there mate!![]()
Once and for all, cranknumbers....
- Killerwhale
Re: Once and for all, cranknumbers....
dfh
The fog clears...Killerwhale wrote:Ahh, sorry....it was in the post just under here "jetting - dyno result"dfh wrote:Maybe its a language thing but I cannot see in any of your posts the rear wheel figure your dyno operator gave you for your bike. BTW were did Phuk say it was knackered?Killerwhale wrote:"in your reluctance to cough up the figure your bike produced"
Your TRX has FCR's & a full system... does it have V2 or similar cams?
Found your printout a bit lacking in info so I can see why you are pondering the results. Phuk's is easier to read, at least the power and torque curves cross in the right place.....
As your dyno man seems to be into bikes that do not go 'round corners it is possible that he uses the "amurrikan" approch where the good 'ol boys have correction factors switched on for barometric pressure, humidity, transmission losses, pumping losses, even what stage in the cycle their wimmin are at. Best ask the operator to print another with no corrections just to be sure.
The obvious thing of course would be to challenge the other owner of the TRX that the dyno man has seen to a bit of a drag race...
DFH
- Killerwhale
Yam9 kentcams....wich will be switched to "special profile" kentcams soon.dfh wrote: The fog clears...
DFH
Thing about the tourque curve could be explained with that i´ve timed the cams myself and i have adjustable camsprockets and......well you get my drift.
I don´t want to shoot the dyno guy as a straight line dude, he did some marvelous work on the other TRX!!
- Killerwhale
Just meant that if curves are all over the shop....then something is knackered and need correction!phuk72 wrote:I was wondering thatdfh wrote:[. BTW were did Phuk say it was knackered?
DFH
- phuk72
