Hi all,
I need to replace perishing rubbers on the lower joints of my 98' TRX.
Upon searching these came up...
EBAY LINK
The image shown is not of a TRX carb and also showing the airbox to carb joint, not the lower two. Are they simply the same part of different rubbers altogether?
Thanks
Carb joint rubbers (I.D please)
00mike00
- Rod.s
Re: Carb joint rubbers (I.D please)
They are correct for the TRX, the sectional image is for the TDM.
I would also check that price with your local dealer as it seems high.
00mike00
Thank you, I will check!Rod.s wrote:They are correct for the TRX, the sectional image is for the TDM.
- Tarwetijger
