Vek
by Vek » Thu Jul 21, 2016 8:36 pm
Hi All, Newbie here.
I am in the process of refreshing/rebuilding my TRX which I bought last year as a project. However when putting the engine back into it's freshly powder coated frame I managed to snap the top rear engine mounting bolt
. I didn't get anywhere near the torque setting before the thread stretched and then the bolt snapped on the thread.
My question is - Have any of you used stainless steel replacements if so where did you get them from and how much? I can get some OEM replacements from a dealer but was wondering if any of you had used anything better? I intend to replace both the top and bottom rear mounting bolts.
Kev.
by cobbadiggabuddyblooo » Fri Jul 22, 2016 6:13 am
My choice would be an OEM bolt from Yamaha or find one at a wreckers.
bagmaker
by bagmaker » Fri Jul 22, 2016 9:28 am
Stainless would not be the bolt of choice there Vec, it will work harden and snap.
See if you cannot find a plated one from somewhere and double check your torque wrench
those who can count
and those who cannot
Vek
by Vek » Fri Jul 22, 2016 9:51 am
Thanks for the advice guys. Guess I'll order the OEM ones from yamaha.
by cobbadiggabuddyblooo » Fri Jul 22, 2016 2:54 pm
Follow the torque specs too from the manual.
it can be downloaded online from here..
Vek
by Vek » Fri Jul 22, 2016 8:44 pm
Are they different from those in the Haynes manual?
by cobbadiggabuddyblooo » Sat Jul 23, 2016 1:30 am
No, they should be the same...
Satoru
by Satoru » Wed Jan 18, 2017 1:58 pm
Hi Vek,
A couple of years ago I did tear away the thread on the lower bolt of the rear shock absorber of my TRX, and I was not using really a lot of force.
Just a couple of months ago I did snap the bolt of the rear brake of the CBR (while removing it!) in a way similar to what happened to you: it stretched first (diameter of the thread in the stretched area was 7.30mm vs 7.80mm elsewhere) and then snapped.
In the latter case I did a mistake I will avoid in the future: I did not use Svitol before force application.
I discussed with a friend that is into metalworking and in his opinion the bolt had the risk of snapping during normal use anyway.
He's kind of an extremist: in his opinion after so many years (20)and miles (50k+) nuts and bolts should all be replaced with new ones for safety reasons because we don't see with the eye the metal fatigue, but is there nonetheless.
Sooo happy moving from Carbon Lorraine A3+ to SBSRS on my gold spots!
