CARBURETTOR TECHNICAL INFO std MIKUNI, FCR 41, TDMR 40
Post by cobbadiggabuddyblooo » Mon Aug 15, 2016 4:36 am
Here is a list of Tech specs I've compiled on the TRX carby set ups in std format as base settings..
FCR 41
Main jet ............ 150
Pilot fuel ........... 48
Jet Needle ........... OCEMP
Needle jet .............
Float needle....... 2.0
Float level ......... 9mm
Pilot screw ....... 1.5
Main air ............ 200
Air screw .......... 1
Intake spigot length 33mm / 26mm in place
( http://www.mikuni-topham.de/ENGLISHSITE ... glish.html )
TDMR 40 B-11
Main jet .......... 145 (180)
Pilot fuel ......... 25 (27.5)
Pilot screw....... 2.5
Jet Needle ........... 10EI1-50
Needle jet ...... P-6
Idle air .......... 120
Float level ...... 13mm
Std TRX850
Main jet ..........142.5
Pilot jet ........... 45
Pilot screw ...... 2.0
Jet Needle ....... 5E185-2/5
Needle jet ....... Y-2
Pilot air jet 1......... 70
Pilot air jet 2........ 1.4
Replacement kits from Keyster KY 0570 ( std TRX/tdm 850 )
http://www.motorcyclespareswarehouse.co ... -parts-kit
Last edited by cobbadiggabuddyblooo on Mon Aug 15, 2016 11:50 am, edited 1 time in total.
Re: CARBURETTOR TECHNICAL INFO std MIKUNI, FCR 41, TDMR 40
Post by cobbadiggabuddyblooo » Mon Aug 15, 2016 4:48 am
Here is a link to the air cut off valve replacements..
http://www.motorcyclespareswarehouse.co ... ve-88-y001
There's no picture but it's the white plastic piece on the side of the std carbies that slowly perishes and leaks air causing issues..
I'm sure someone can expand who has experienced this with the symptoms ..
Any extra info please feel free to expand this thread..
Ragnar
Post by Ragnar » Thu Aug 18, 2016 7:17 pm
Here's the picture (from the German Forum)
gavtron
Post by gavtron » Sun Nov 06, 2016 9:08 pm
Would anyone know where to get hold of standard carb parts? Have a crack that I've had to try and fix on the float cover where the bleed screw locates so would ideally like to replace in case my 'fix' fails.
Post by Mincehead » Sun Nov 06, 2016 10:15 pm
gavtron wrote:Would anyone know where to get hold of standard carb parts? Have a crack that I've had to try and fix on the float cover where the bleed screw locates so would ideally like to replace in case my 'fix' fails.
Allen's: http://www.allensperformance.co.uk/ might be able to help.
