Keyster carb kits
pertrx850
Keyster carb kits
Post by pertrx850 » Thu Nov 28, 2013 8:44 am
Hi!
Has anyone used the Keyster carb kits? (rebuild kit including emulsion tubes, jes etc.)
If so, are they good?
Thanks!
Regards,
Per
Re: Keyster carb kits
Post by alextrx850 » Thu Nov 28, 2013 10:46 am
If it is the Keyster KY - 0570 kit then it's a good kit.
Most of us around Brisbane have the kit and is good quality with value....
Advise fitting the needle clip itself in the lower notch instead of the middle as you would....three notches to the needle I believe....can be a little lean otherwise.
Yep..a good fit up.
pertrx850
Post by pertrx850 » Thu Nov 28, 2013 5:35 pm
Thanks!
Regards,
Per
pertrx850
Post by pertrx850 » Fri Jan 03, 2014 11:46 pm
Ordered and fitted (partly)! Seems to work fine when running it outside the garage. Longin for spring already :)
jerrah
Post by jerrah » Sat Mar 08, 2014 9:29 am
Where did these people of Brisbane purchase their Keyster carb kits? :)
Post by alextrx850 » Sat Mar 08, 2014 10:05 am
They were advertised on e-Bay..vendor was in Australia which was handy.
Post by Con Rod » Sun Mar 09, 2014 11:10 am
Trixed
Post by Trixed » Sun Mar 09, 2014 12:58 pm
Con Rod wrote:this place sells them in Australia
http://www.motorcyclespareswarehouse.com.au/
specifically, these ones
http://www.motorcyclespareswarehouse.co ... aha/tdm850
I bought it from the above workshop in person. They were very helpful and professional. Works really well on the TRX.
Recommend the kit.
