Leaking Fork Seal
scotty12
Leaking Fork Seal
Post by scotty12 » Fri Oct 18, 2013 3:37 pm
Hi,
Fairly new to the Forum, but thought I would pass this on.
I had a weeping Fork Oil seal on my 96 TRX, so thought I would have to change the seal. Not an easy job, but I had changed seals before on another bike, so knew how to do it & had the trusty Haynes manual at hand.
While searching on line for replacement seals I came across, what Is in effect a thin piece of plastic, shaped with a hook on the end, it's called a "Seal Mate". The description says, that in most cases oil seal leaks are caused by a bit of crap (my word), being stuck under the seal lip, and that this "tool" can clean out the seal & fix the leak.
I was dubious, but at about £4 thought I would give it a try, and guess what, it worked! took me about 5 minutes. Now no leak.
If you have a leaking fork seal, it's worth a try. Hope this helps someone.
Mick
Snod Blatter
Re: Leaking Fork Seal
Post by Snod Blatter » Fri Oct 18, 2013 5:14 pm
I have heard that these do work but not for very long.. Keep us updated!
Post by misterdimwiddy » Fri Oct 18, 2013 8:28 pm
I have got one odd spare fork seal here in my box of bits if it does leak.
I am assuming you have stock forks and are in the UK!
Shame to bin it but no use to me.
QuickDraw
Post by QuickDraw » Fri Oct 18, 2013 10:13 pm
I've used one of these. I actually made my own by cutting out an ice-cream container lid. Did the trick for me. 3000 kms - so far so good.
Post by cobbadiggabuddyblooo » Sat Oct 19, 2013 12:00 am
Mmmmm good excuse to tell Janet I need more ice cream
scotty12
Post by scotty12 » Tue Oct 22, 2013 11:21 am
Snod Blatter wrote:I have heard that these do work but not for very long.. Keep us updated!
Thanks for all replies, done about 500 miles so far and no leak.
Post by Con Rod » Tue Oct 22, 2013 1:56 pm
yep this can work, any thin flexible plastic will do. Only thing I would suggest would be to change the oil as there is probably a fair amount of "crap" and water and what not has made its way in and oils changes are cheap and easy
