TRX Master Cylinder
Wally
TRX Master Cylinder
Post by Wally » Wed Jul 03, 2013 9:18 am
Wondering what size master cylinder I would use with a single TRX front calliper
Re: TRX Master Cylinder
Post by cobbadiggabuddyblooo » Wed Jul 03, 2013 10:02 am
Go with the std single pot M/C fitted to the bike and get a feel.. This will give you a reference point.. Note the size then go up or down to get what is optimum. Much the same when you change your std Trx callipers to BLUESPOTS .. With the larger std 5/8 Trx will feel :? Well you don't really its a bit hard and loose a bit of sensitivity but it still works fine but when you use a smaller 14mm MC you can squeeze to you hearts content and find the optimum balance you require...
Wally
Post by Wally » Wed Jul 03, 2013 10:26 am
