Can someone help as I'd like to find out if the TDM forks measure the same at the top of the bottom fork slider ( where the fork seal sits) as the TRX. 61.5 (95 to 97)and 63.5mm(1997 to 99).. And the width from the centres of the fork legs (TRX from memory is around 200mm) the reason being I'm looking at getting fork braces manufactured and if there is a common measurement then they should suit both bikes. The manufacturer in the U.S. and can get his hands on a 92 or 93 model TDM to use as a test for the brace also so that's the primary reason. So I'm hoping if it can fit the TDM it will fit the TRX if both measure up the same.
http://tkat.com/forkbrace/diagram.htm
I'm after the measurements off the link from as many TDM models (maybe they have changed dimentions over the years)
TDM and TRX forks
TDM and TRX forks
curck
Re: TDM and TRX forks
Fork of TDM fits the TRX.
Greetings & Respect,
curck
curck
