spanner
by spanner » Sun Sep 09, 2012 2:15 pm
hi all
i want to lift my trx up so i can access the front wheel forks ect as i have a bit of a head shake when i slow down, but not sure how to do it,
or where to jack her up from. looks like its a choice between an abbus center stand or exhaust,s off and maybe
jack up from the engine some where
, any tips or advice please.
by Con Rod » Sun Sep 09, 2012 2:24 pm
Paddock stand at the rear and a jack and a price of wood under the header pipes, they are well strong enough to take the weight.
I have done this many many times.
spanner
by spanner » Sun Sep 09, 2012 2:32 pm
cheers con rod ..........
by trixynut » Sun Sep 09, 2012 7:28 pm
Or piece of 9mm bar through loops at front of engine and an axle dtsnd either side or blocks of wood. Dont need rear paddock stsnd for this.
by cobbadiggabuddyblooo » Mon Sep 10, 2012 2:42 pm
Con Rod wrote: a jack and a price of wood under the header pipes
Now THAT makes Cents
spanner
by spanner » Sat Sep 15, 2012 5:19 pm
cheers chaps,
removed front wheel as i suspected the bearings had gone, there was a fair bit of movement in the spindle. so ive orderd new bearings but there just the same
theres still alot of play spindle.
