I have been thinking for some time that my speedo is clocking up the mileage quicker than it should be. I usually ride with a guy on a new Aprllia with digital clocks and there is always some difference in the mileage we think we have done on a ride, with mine always being higher. I went to Cadwell Park at the weekend for the BSB meet and did what I thought was 439 miles and his was saying 389, some 50 miles less. The other person I was riding with also had a reading of about 389 miles!! Does anyone know of how I could find out if it is my speedo is running incorrectly? I obviously don't want my mileage clocking up anymore than its needs to be.
kev
speedo is running to fast?
kevj
- cal
Re: speedo is running to fast?
Looks like you have a duff odometer, but is the speedo reading high as well? Try running alongside a freind at set speeds 20 30 40 50 etc and see if there is a difference, this may be the reason the miles are high. You could probably get it re calibrated but you might be cheaper to get a new one (second hand).
Cal
Maybe just ride slower??
Thats an interesting one. If its not a faulty speedo, it must be a gearing issue somewhere.
So, process of elimination, presuming you have the right size front wheel and tyre (obvious I know but..) and considering there is no 'gearing' in the cable then that can be ruled out, then it could be you have a speedo drive on the bike off another bike with a bigger/smaller wheel (maybe a TDM's, would that fit?)
Otherwise its the speedo, but as the mileometer is gear driven AFAK, then its difficult to see how it could be faulty??
kevj
when riding home on moday night i thought i was doing 90 - 100 mph ( i hope there is no coppers reading this) but the others said they were 80 - 85mph!!!
- slow codger
kevj
yeah original wheels and clocks.
- cal
Must be the speedo head calibration then if all else is original, but....unless you bought the bike brand new or you have noticed a change in the speedo readings, then the bike may have been giving false readings all the time you have had it,so could be a wrong speedo drive fitted before you got it.
If you know anyone else with a trx you could maybe try swapping the drives (or looking for obvious differences first), this would be a cheap (
free!
) and easy test.
If that is the case then I think you would also be within your rights to ligitamatley (spellchecker!) alter the odometer reading ie divide by 100 and x by 85, Changing the odometer reading can be illegal
so I would check up on that first. but if the wrong part has been fitted since you got the bike and you can remember the milage when you got it I personally dont see the problem,
If the speedo drive is correct then it all points to the speedo head being out of calibration ....
Cal
