digital speedo fitting
Posted: Wed Oct 27, 2010 10:16 pm
by edengreylag
Picked up a great wee koso speedometer and i'll be fitting it this week.Should i strip off the old wiring loom or simply cut the ends off my warning bulbs etc and connect them directly to the wiring on the new speedo?
Re: digital speedo fitting
Posted: Wed Oct 27, 2010 10:20 pm
All depends if you ever want to go back to standard or not.
Personally I would use connectors spliced into the wires and leave the unused terminal blocks/connectors just in case.
Posted: Thu Oct 28, 2010 1:49 am
by devlin
....or make up some short converter leads. old plug one end new plug other end with about 5 cm in between.
Posted: Thu Oct 28, 2010 5:47 pm
by edengreylag
All fitted apart from the neutral .Apparently goes to foot stand unit to get the neutral reading if that makes sense.Another 2 hours mechanic labour saved when it goes for its final check and MOT!!!
Posted: Fri Oct 29, 2010 6:16 pm
by edengreylag
spent all day trying to get the neutral to work.The seller advised me to connect to the side stand switch.I tried on both wires that go down to the switch.One wire is dead an does not illuminate the green neutral.the other does light it up but stays green even when in gear.It must just be earthing the damned thing or something.Anyone any ideads ??????
Posted: Sat Oct 30, 2010 9:00 am
by Kayla
edengreylag wrote:spent all day trying to get the neutral to work.The seller advised me to connect to the side stand switch.I tried on both wires that go down to the switch.One wire is dead an does not illuminate the green neutral.the other does light it up but stays green even when in gear.It must just be earthing the damned thing or something.Anyone any ideads ??????
Ah, yes. (I'm reading this after replying to your PM!)
It sounds like maybe the seller bodged around using a real neutral by using the sidestand cutout switch- the thinking being that if the stand's down, the bike is in neutral. Was the speedo being used on another TRX?
Track the wire down that illuminates the neutral light on the original idiot lights and use that. Is there a wire that comes out of the cases near the stator that's a neutral wire?
Posted: Sun Oct 31, 2010 8:04 pm
by edengreylag
getting the bike in for the fork seals,cam chain adjustment etc and the MOT this week so they can do this final speedo fitment too.My brains fried now lol.
Posted: Wed Nov 03, 2010 10:54 am
by rbaron25
Bugger was going to fit a digital speedo but methinks I do not have the electrical nouse after reading the above.. except to fry all said components and bike... maybe local autoleccy then...
