Safe max rpm
Kenny
Safe max rpm
Post by Kenny » Tue Jul 13, 2010 6:33 pm
A question for the tuners out there. What is the safe max rpm for a TRX I hear of people revving to 9000rpm+ is this safe?
Re: Safe max rpm
Post by Mincehead » Tue Jul 13, 2010 6:53 pm
Yep, they`ll go past that but not reliably if they`re stock inside.
The Over OV15 TDM motor based racer revved past 9,500 but they didn`t need it to with 115 bhp at 8,500 rpm.
http://www.totalmotorcycle.com/photos/p ... OV-15A.htm
Re: Safe max rpm
Post by phuk72 » Tue Jul 13, 2010 8:20 pm
Yes it is safe to rev to 9.5k
Re: Safe max rpm
Post by trixynut » Tue Jul 13, 2010 9:55 pm
The 'full advance' TPS bypass mod raises to rev limit to 10,000 iirc. perfectly safe.
Kenny
Re: Safe max rpm
Post by Kenny » Tue Jul 13, 2010 10:23 pm
trixynut wrote:The 'full advance' TPS bypass mod raises to rev limit to 10,000 iirc. perfectly safe.
:shock: Are you for real 10,000rpm :shock: on a std motor safe :shock: :shock: holy cow batman
Re: Safe max rpm
Post by Mincehead » Tue Jul 13, 2010 10:31 pm
I wouldn`t do it even if I could, that`s through the useable power band and out the other side.If Over managed to get 115 bhp at 8,500 rpm you can bet that revving the motor beyond that is totally unnecessary. :wink:
Kenny
Re: Safe max rpm
Post by Kenny » Tue Jul 13, 2010 11:09 pm
Im just curious thats all as on my dyno session it revved easily to 9000rpm and peaked at 8000rpm I just wanted to know if this is ok to go that high into the red as it went there so readily.
Re: Safe max rpm
Post by trixynut » Tue Jul 13, 2010 11:14 pm
All motors are all built within quite low tolerances.
If you've ever seen a motor being tested at a factory, the throttle is pinned to the max and left for a good while!
The TRX lump is quite a solid 'lazy' motor so it can take it.
BTW the 10k maximum limit with the tps mod is intended for a tuned motor to get the best from it.
Kevtrx849
Moderator
Re: Safe max rpm
Post by Kevtrx849 » Wed Jul 14, 2010 4:59 am
My track bike with the Over cdi fitted would bounce off the limiter regularly at Oran park coming onto the straight. Got there so quickly. Didn't seem to hurt the motor at all. The standard motor doesn't make any more power after 7600 rpm so it's pointless going there really.
( HENRY FORD )
